Hello,
I have made a feeder for my aqua tank. It's a spinning wheel which is moved by a stepper. At the moment I can test it using serial commands. That works pretty well.
Here is the working code.
#include <AccelStepper.h>
#include <Servo.h>
#define dirPin 33
#define stepPin 32
#define motorInterfaceType 1
#define SERVO_PIN 26 // ESP32 pin GIOP26 connected to servo motor
Servo servoMotor;
String command;
const int MS1 = 14;
const int MS2 = 13;
const int MS3 = 12;
int MOTOR_STEPS = 200;
// Create a new instance of the AccelStepper class:
AccelStepper stepper = AccelStepper(motorInterfaceType, stepPin, dirPin);
const int sensorPin = 15; //photoelectric pin
int lightInit; // initial value
int lightVal; // light reading
bool nulled = false;
bool executed = false;
bool going = false;
/* Postions for boxes
const int g1 = -260;
const int g2 = -60;
const int g3 = 175;
const int g4 = 395;
const int g5 = 600;
const int b1 = -480;
const int b2 = -695;
const int b3 = -900;
const int b4 = -1115;
const int b5 = -1340;
const int s1 = 795;
const int s2 = 1005;
const int s3 = 1220;
const int s4 = 1433;
const int s5 = 1650;
void nullposition() {
stepper.enableOutputs();
lightVal = analogRead(sensorPin);
Serial.println("go to null position");
Serial.println(lightVal);
stepper.setMaxSpeed(300);
if (executed == false && lightVal > 300) {
stepper.runToNewPosition(-100);
Serial.println("executed - true");
executed = true;
delay(2000);
lightVal = analogRead(sensorPin); // read the current light levels
stepper.moveTo(4000);
while (lightVal < 300 && nulled != true) {// Full speed up to 300
stepper.run();
stepper.stop(); // Stop as fast as possible: sets new target
stepper.runToPosition();
stepper.setCurrentPosition(0); //set steppercounter to 0 aufter reaching endstop switch
nulled = true;
Serial.println("null position set");
Serial.println(stepper.currentPosition());
stepper.setMaxSpeed(1000);
stepper.disableOutputs();
// delay(10);
servoMotor.attach(SERVO_PIN); // attaches the servo on ESP32 pin
lightInit = analogRead(sensorPin);
Serial.println(lightInit);
stepper.setPinsInverted(false, false, true);
stepper.setEnablePin(25);
pinMode(MS1, OUTPUT);
pinMode(MS2, OUTPUT);
pinMode(MS3, OUTPUT);
digitalWrite(MS1, HIGH);
digitalWrite(MS2, HIGH);
digitalWrite(MS3, HIGH);
// Set the maximum speed and acceleration:
stepper.setMaxSpeed(1000); //(1000)
stepper.setAcceleration(1000); //(1000)
nullposition();
void moveposition() {
MOTOR_STEPS = command.toInt();
if (nulled == true) {
Serial.print("fahren");
stepper.moveTo(MOTOR_STEPS);
while (stepper.currentPosition() != MOTOR_STEPS) {
stepper.run();
// nulled = false;
//stepper.disableOutputs();
void empty()
// rotates from 110 degrees to 0 degrees
for (int pos = 110; pos >= 0; pos -= 1) {
servoMotor.write(pos);
delay(20); // waits 15ms to reach the position
for (int pos = 0; pos <= 110; pos += 1) {
// in steps of 10 degree
//delay(5000);
moveemptyposition();
void moveemptyposition() {
MOTOR_STEPS = stepper.currentPosition() - 850;
stepper.run();
MOTOR_STEPS = -200;
stepper.run();
nulled = false;
nullposition();
if (Serial.available()) {
command = Serial.readStringUntil('\n');
command.trim();
Serial.print("you have typed: ");
Serial.println(command);
if (command.equals("99")) {
//Serial.println("go to null position");
nulled = false;
nullposition();
else if (command.equals("999")) {
empty();
else {
moveposition();
In future I want to trigger the events using MQTT. So it is necessary to add a wifi connection.
As soon as I connect the device to wifi, the serial commands do not work anymore and also for example the automated initial nullposition() to calibrate the device with using a photoelectric endstop switch does not work anymore. It starts moving but it does not stop passing the sensor.
I have removed everything additional in the code and found out that as soon as setup_wifi(); is executed, these things do not work anymore.
any suggestions?
here is the extended code:
#include <Servo.h>
#include "WiFi.h"
#include <PubSubClient.h>
#include <WiFiUdp.h>
#define dirPin 33
#define stepPin 32
String temp = ""; //temporär
String packet = "";
String received = "";
Servo servoMotor;
//WIFI
const char *ssid = "myssid"; //your Wifi SSID
const char *password = "password";
const char* deviceName = "esp32_feeder";
String command;
const int MS1 = 14;
const int MS2 = 13;
const int MS3 = 12;
const short int LED_BUILTIN = 1; //GPIO1
bool going = false;
const int g2 = -60;
const int g3 = 175;
const int g4 = 395;
const int g5 = 600;
const int s1 = 795;
String color; // color reading
const char* mqtt_server = "192.168.178.44";
const int mqttPort = 1883;
const char* mqttUser = "mosq";
const char* mqttPassword = "mqttpassword";
//mqtt ende
// WiFi connect timeout per AP. Increase when connecting takes longer.
const uint32_t connectTimeoutMs = 5000;
unsigned long previousMillis = 0; // will store last time updated
const long interval = 15000; // interval at which to run muss 15000 sein
unsigned long previousMillisLED = 0; // will store last time LED was updated
unsigned long intervalLED = 1000; // interval at which to blink (milliseconds)
int ledState = LOW;
WiFiClient espClient;
PubSubClient client(espClient);
executed = true;
delay(2000);
stepper.run();
nulled = true;
// delay(10);
setup_wifi();
pinMode(LED_BUILTIN, OUTPUT); // Initialize the BUILTIN_LED1 pin as an output
digitalWrite(LED_BUILTIN, HIGH); // Turn the LED off by making the voltage HIGH
client.setServer(mqtt_server, mqttPort);
client.setCallback(callback);
reconnect();
nullposition();
void callback(char* topic, byte* payload, unsigned int length) {
String sTopic = String(topic);
Serial.print("topic empfangen: ");
Serial.println(String(topic));
if (sTopic == "aqua/received") {
temp = "";
for (int i = 0; i < length; i++) {
temp += ((char)payload[i]);
received = temp;
Serial.println(received);
void setup_wifi() {
WiFi.begin(ssid, password);
Serial.println("Connecting to WiFi..");
Serial.println("Connected to the WiFi network");
void reconnect() {
if (WiFi.status() != WL_CONNECTED) {
Serial.println("WiFi not connected!");
void setup_wifi();
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
char clientid[25];
snprintf(clientid, 25, "WIFI-Display-%08X", "12345"); //this adds the mac address to the client for a unique id
Serial.print("Client ID: ");
Serial.println(clientid);
if (client.connect(clientid)) {
Serial.println("connected");
client.subscribe("aqua/received");
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 1 second before retrying
nullposition();
stepper.run();
// nulled = false;
void empty()
//delay(5000);
stepper.run();
MOTOR_STEPS = -200;
stepper.run();
nulled = false;
nullposition();
command.trim();
nulled = false;
nullposition();
empty();
else {
moveposition();
if (WiFi.status() == WL_CONNECTED) { //blink blue LED while wifi is connected
unsigned long currentMillisLED = millis();
if (currentMillisLED - previousMillisLED > intervalLED) {
// save the last time you blinked the LED
previousMillisLED = currentMillisLED;
ledState = !ledState;
// if the LED is off turn it on and vice-versa:
if (ledState == HIGH) {
digitalWrite(BUILTIN_LED1, LOW);
intervalLED = 100;
digitalWrite(BUILTIN_LED1, HIGH);
intervalLED = 3000;
// reconnect();
if (currentMillis - previousMillis >= interval) {
Serial.print("received momentan: ");
if (received == "true") {
//measure();
Serial.print("received jetzt: ");
Serial.println("publish werte zu smartphone");
// client.publish("aqua/display/temperatur", tempStringaqua);
// client.publish("aqua/display/zeit", t.c_str());
received = "false";
// client.loop();
void convert2Json()
// Temperature in Celsius
packet = "";
packet.concat(("{\"temp\": "));
// packet.concat(temperature);
packet.concat("}");
Serial.println(packet);
//client.publish("sensors/room/aqua", packet.c_str());
Serial.println("sensors/room/aqua published");
