From the documentation: Operation
This module operates by computing a step time in microseconds. The step time is recomputed after each step and after speed and acceleration parameters are changed by the caller. The time of each step is recorded in microseconds. The run() function steps the motor once if a new step is due. The run() function must be called frequently until the motor is in the desired position, after which time run() will do nothing.
