Accelstepper
I am programming for two stepper motors and arduino uno. I haven't yet seen any examples of changing the motor position in degrees. I want to move each motor by different increments at the press of a button. Specifically, motor 1 needs to move about 14 degrees followed by motor 2 moving 180 degrees. Any chance of getting away with that?
Yes. You KNOW how many steps it takes your stepper to rotate 360 degrees, so rotating a specific number of degrees is simple math to calculate the number of steps.
Thanks for the fast reply, yes it is simple math and yes I know the steps per revolution, but, I had to know if it would respond to an instruction in degrees mostly to know if the board would do the math -
AccelStepper only does steps. If you want degrees (or inches or meters) you must do the conversion to steps in your code.
Thanks -
