accendere, spegnere e ricavare stato di un led con ethernet shield
Hi all,
I wrote a program that should perform the following tasks:
  • read the led status and send it to a php page which update a table in my db.
  • receive commands from a webpage about turn on or off the led
The code is the following:
#include <SPI.h>
#include <UIPEthernet.h>
byte mac[] = { 0x90, 0xa2, 0xda, 0x0d, 0x05, 0x18 };
IPAddress ip(192,168,1,7);
char myserver[] = "www.miodominio.com";
const int DIMENSIONE_BUFFER = 10;  // usato per salvare il parametro
char buffer [DIMENSIONE_BUFFER+1]; // termina con il carattere nullo
int pin;
int stato=0;
int ledPin = 6;
EthernetServer server(80);//server port
EthernetClient client;
void setup(){
 Ethernet.begin(mac, ip);
 server.begin();
 pinMode(ledPin, OUTPUT);
 Serial.println("ready");
void loop(){
 UpdateStatus();
 if (client) {
 while (client.connected()) {
   if(client.available()){
    if(client.find("led"))
            // cancello il buffer salvato in precedenza, se esiste
            memset(buffer,0,sizeof(buffer));
            // leggo fino al carattere &
            client.findUntil("&","\n\r");
            //memorizzo il numero che ritrovo nella stringa passata dopo il carattere '&'
            pin = client.parseInt();
 if( pin == 0 ) { // search for 'GET'
 Serial.print("Digital pin low ");
 digitalWrite(ledPin, LOW);
 client.println("Content-Type: text/html");
 client.println("Access-Control-Allow-Origin: *");
 client.println("messaggio");
 client.println();
 if( pin == 1 ) { // search for 'GET'
 Serial.print("Digital pin high ");
 digitalWrite(ledPin, HIGH);
 client.println();
 // give the web browser time to receive the data
 delay(1);
 client.stop();
void UpdateStatus()
  if (client.connect(myserver, 80))
     stato = digitalRead(ledPin);
 Serial.print("stato:");
 Serial.print(stato);
 // send the HTTP PUT request:
    client.print("GET /progetti_arduino/ledon/update_status.php?status=");
    client.print(stato);
    client.println(" HTTP/1.0");
    client.println("Host: www.miodominio.com");
    client.println();
else {
    // if you couldn't make a connection:
    Serial.println("connection failed");
    Serial.println("disconnecting.");
  while(client.connected() && !client.available()) delay(1); //waits for data
  while (client.connected() || client.available()) { //connected or data available
    char c = client.read();
    Serial.print(c);
When I tell to arduino to turn on or off the led by a web page, sometimes arduino reply correctly performing the command that I sent, sometimes not
Can someone explain me what it depends from?
Thank you very much.
