Accerlometer code not working?
hello this code in compiling but I am just getting 0 , 0 , 0 for xyz on every reading?
any thoughts?
#include "Wire.h"
#include "SPI.h"
LIS3DH myIMU; //Default constructor is I2C, addr 0x19.
delay(1000); //relax...
Serial.println("Processor came out of reset.\n");
//Call .begin() to configure the IMU
myIMU.begin();
//Get all parameters
Serial.print("\nAccelerometer:\n");
Serial.print(" X = ");
Serial.println(myIMU.readFloatAccelX(), 4);
Serial.print(" Y = ");
Serial.println(myIMU.readFloatAccelY(), 4);
Serial.print(" Z = ");
Serial.println(myIMU.readFloatAccelZ(), 4);
ive used this one now and it says couldn’t start.
not sure if its something to do with the I2C or SPI.
// Used for software SPI
#define LIS3DH_CLK 13
#define LIS3DH_MISO 12
#define LIS3DH_MOSI 11
// Used for hardware & software SPI
#define LIS3DH_CS 10
// software SPI
//Adafruit_LIS3DH lis = Adafruit_LIS3DH(LIS3DH_CS, LIS3DH_MOSI, LIS3DH_MISO, LIS3DH_CLK);
// hardware SPI
//Adafruit_LIS3DH lis = Adafruit_LIS3DH(LIS3DH_CS);
// I2C
Adafruit_LIS3DH lis = Adafruit_LIS3DH();
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_LIS3DH.h>
#include <Adafruit_Sensor.h>
// software SPI
// hardware SPI
// I2C
void setup(void) {
while (!Serial) delay(10); // will pause Zero, Leonardo, etc until serial console opens
Serial.println(“LIS3DH test!”);
if (! lis.begin(0x19)) { // change this to 0x19 for alternative i2c address
Serial.println(“Couldnt start”);
while (1) yield();
Serial.println(“LIS3DH found!”);
lis.setRange(LIS3DH_RANGE_4_G); // 2, 4, 8 or 16 G!
Serial.print("Range = "); Serial.print(2 << lis.getRange());
Serial.println(“G”);
lis.read(); // get X Y and Z data at once
// Then print out the raw data
Serial.print("X: “); Serial.print(lis.x);
Serial.print(” \tY: “); Serial.print(lis.y);
Serial.print(” \tZ: "); Serial.print(lis.z);
/* Or…get a new sensor event, normalized */
sensors_event_t event;
lis.getEvent(&event);
/* Display the results (acceleration is measured in m/s^2) */
Serial.print("\t\tX: “); Serial.print(event.acceleration.x);
Serial.print(” \tY: “); Serial.print(event.acceleration.y);
Serial.print(” \tZ: “); Serial.print(event.acceleration.z);
Serial.println(” m/s^2 ");
delay(200);
Run an I2C scanner and see if it detects your accelerometer
