Access control with RC522 + Problem with rc522 continuous reading
Greetings, I'm trying to implement an access control system using arduino with a rc522 rfid reader. What I want is basically to command the servo to one position (open) when the id read from the tag is the "right" one and to drive it to another position (close) when the id is not allowed or there isn't any tag being read. The servo motor must stay in the open position as long as the allowed tag remains in range, and it should go back to the close position when the allowed tag is removed.
So far I have figured out how to read de id from the tags and use that information to activate a servo, the problem I'm having is that I haven't been able to command the servo for going back to the close position when the tag is removed.
other problem I'm having is when the allowed tag stays for a while in the range of detection, the rc522 keeps looking for a new tag and that appears to interfere with the functioning of the servo.
Hope you can help me.
Thanks
P.D. I'm working with arduino mega 2560 and the rc522 rfid reader, the library I'm using is the one from: GitHub - miguelbalboa/rfid: Arduino RFID Library for MFRC522
#include <SPI.h>
#include <MFRC522.h>
#include <Servo.h>
#define SS_PIN 53
#define RST_PIN 5
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
byte cardPresent;
Servo myservo;  // create servo object to control a servo
int pos = 0;    // variable to store the servo position
 Serial.begin(9600); // Initialize serial communications with the PC
 SPI.begin(); // Init SPI bus
 mfrc522.PCD_Init(); // Init MFRC522 card
 mfrc522.PCD_SetAntennaGain(mfrc522.RxGain_max);
   myservo.attach(11);  // attaches the servo on pin 11 to the servo object
 // Look for new cards
 if (mfrc522.PICC_IsNewCardPresent())
  if  (mfrc522.PICC_ReadCardSerial())
      String rfidUid = "";
       for (byte i = 0; i < mfrc522.uid.size; i++)
        rfidUid += String(mfrc522.uid.uidByte[i] < 0x10 ? "0" : "");
        rfidUid += String(mfrc522.uid.uidByte[i], HEX);
       if (rfidUid=="59ac809e")
          Serial.println("ID: ");
        Serial.println(rfidUid);
        Serial.println("access granted");
        myservo.write(130);  // set servo to open position
        Serial.println("access denied");
        myservo.write(0);
           myservo.write(0);  // set servo to close position
The problem is that the reader will not give you any tag removed information, it will only give you the data the first time the tag is read. That is how that reader is designed. In fact most readers are designed like this although there is nothing stopping you designing a continuous reading reader.
One way round this is to constantly reset the reader when you see a tag in the field and see if it still reads. However this is a fudge at best and it takes about half a second to read a tag from reset so the time accuracy is not very good.
No that is not the problem, what problem are you having with the servo, it is most likely to be power supply related.
Grumpy_Mike:
The problem is that the reader will not give you any tag removed information, it will only give you the data the first time the tag is read. That is how that reader is designed. In fact most readers are designed like this ...
that's bad news, I guess I will have to implement something like a sensor that detects the presence of the card so when it stop seeing the tag activates the servo.
