Once I move the temperature sensor code to a function (say void tempRead() {//code here}) and leave it in sketch.ino everything runs ok, however when I move tempRead function to a new file with extension *.h or *.cpp or *.ino I immediately get error that tempC and tempF are not defined.
That was meant to represent any file with .h extension.
Yes, I did.
for instance main file is sketch.ino and tempsensor.h with all values and function. I also tried creating separate file temps.cpp or temps.h or temps.ino for a function only - included corresponding name in sketch.ino and no luck.
Do I have to include sketch.ino in tempsensor.h fine in addition to <Arduino.h>?
#ifndef STARTLCD_H
#define STARTLCD_H
LiquidCrystal_I2C lcd(0x27, 20, 4); // set the LCD address to 0x27 for a 16 chars and 2 line display
#endif
#include "humanTime.h"
void humanTime() {
unsigned long times = millis();
unsigned long millisec = times % 100;
unsigned long tseconds = times / 1000;
unsigned long seconds = tseconds % 60;
unsigned long tminutes = tseconds / 60;
unsigned long minutes = tminutes % 60;
unsigned long thours = tminutes / 60;
unsigned long hours = thours % 24;
lcd.setCursor(0, 1);
lcd.print("Time ON: ");
if (thours < 10) {
lcd.print("0");
lcd.print(thours);
lcd.print(":");
if (minutes < 10) {
lcd.print("0");
lcd.print(minutes);
lcd.print(":");
if (seconds < 10) {
lcd.print("0");
lcd.print(seconds);
lcd.print(".");
lcd.print(millisec);
I get these errors:
/private/var/folders/z3/q3k2ybd52j9f6157nzp8jnww0000gn/T/arduino-sketch-D4ACB24F437CE32DEFD15ED8D5CA1065/sketch/humanTime.cpp.o (symbol from plugin): In function `lcd':
(.text+0x0): multiple definition of `lcd'
/private/var/folders/z3/q3k2ybd52j9f6157nzp8jnww0000gn/T/arduino-sketch-D4ACB24F437CE32DEFD15ED8D5CA1065/sketch/dustFairy_2.ino.cpp.o (symbol from plugin):(.text+0x0): first defined here
collect2: error: ld returned 1 exit status
Compilation error: exit status 1
That often happens when you define a global variable in a .h file and include the .h file in multiple places. You have: LiquidCrystal_I2C lcd(0x27, 20, 4); // set the LCD address to 0x27 for a 16 chars and 2 line display
in both sketch.ino and humanTime.cpp. That declaration should only be in one place.
Change 'startLCD.h' to:
#ifndef STARTLCD_H
#define STARTLCD_H
extern LiquidCrystal_I2C lcd; // set the LCD address to 0x27 for a 16 chars and 2 line display
#endif
and add this line to your main sketch: LiquidCrystal_I2C lcd(0x27, 20, 4); // set the LCD address to 0x27 for a 16 chars and 2 line display
Thank you for the reply! I am experimenting with other functions. For the reasons unknown to me yet only certain variables has to be placed in .cpp file or .ino file to work properly.
For example:
if I keep float pressureValue = 0.0; in pressureSensor.h then I get the error, however if I place it in sketch.ino or in pressureSensor.cpp directly it works ok.
And also if place void pressureSensor(){/*code here*/} only in .h file without creating .cpp - it also works ok. Is it normal practice?
#ifndef PRESSURESENSOR_H
#define PRESSURESENSOR_H
#include "Arduino.h"
const int pressureInput = A1; //analog input pin for the pressure transducer
const int pressureZero = 98.6; //analog reading of pressure transducer at 0psi
const int pressureMax = 921.6; //analog reading of pressure transducer at 100psi
const int pressuretransducermaxPSI = 300; //psi value of transducer being used
extern void pressureSensorRead();
#endif
pressureSensor.cpp
#include "pressureSensor.h"
// why this guy has to live here?
float pressureValue = 0.0; //variable to store the value coming from the pressure transducer
void pressureSensorRead(){
//pressure sensor begin
pressureValue = analogRead(pressureInput); //reads value from input pin and assigns to variable
pressureValue = ((pressureValue - pressureZero) * pressuretransducermaxPSI) / (pressureMax - pressureZero); //conversion equation to convert analog reading to psi
//this line in .h file causes error. As I originally had it.
#endif
pressureSensor.cpp
ERROR TEXT START
/private/var/folders/z3/q3k2ybd52j9f6157nzp8jnww0000gn/T/arduino-sketch-ABC400A390B2AEF0CC63234EE757BE66/sketch/sketch.ino.cpp.o (symbol from plugin): In function `setup':
(.text+0x0): multiple definition of `pressureValue'
/private/var/folders/z3/q3k2ybd52j9f6157nzp8jnww0000gn/T/arduino-sketch-ABC400A390B2AEF0CC63234EE757BE66/sketch/pressureSensor.cpp.o (symbol from plugin):(.text+0x0): first defined here
Compilation error: exit status 1 END
How to determine which one goes in .cpp?
Aren't they all defined as global variables?
Is it better to place them in .cpp file?
If you put the definition of a global variable or function in a .h file AND INCLUDE THE .h FILE IN MORE THAN ONE .ino/.cpp FILE then you will have the same global variable or function defined twice and get an error.
ONLY if the .h file is not included, directly or indirectly, in more than one .ino/.cpp file of your sketch.
