Access GPIO on linux side
Hi all,
I'm trying to get the gpio readings working on the linux side so I can later on work with DS18B20 temperature sensor.
When executing the example code
gpio5 = GPIO("/dev/gpiochip5", 5, "in")
value5 = int(gpio5.read())
print("GPIO5 = %d" % value5)
The following error occurred
Traceback (most recent call last):
  File "/usr/local/lib/python3.10/site-packages/periphery/gpio.py", line 539, in _open
    self._chip_fd = os.open(path, 0)
FileNotFoundError: [Errno 2] No such file or directory: '/dev/gpiochip5'
During handling of the above exception, another exception occurred:
  File "/app/gpios.py", line 9, in <module>
  File "/usr/local/lib/python3.10/site-packages/periphery/gpio.py", line 496, in __init__
    self._open(path, line, direction, edge, bias, drive, inverted, label)
  File "/usr/local/lib/python3.10/site-packages/periphery/gpio.py", line 541, in _open
    raise GPIOError(e.errno, "Opening GPIO chip: " + e.strerror)
periphery.gpio.GPIOError: [Errno 2] Opening GPIO chip: No such file or directory
Any help would be appreciated!
Thanks
Hello @chen121617
Please stop the x8-devel container and try again :slight_smile:
use this instead
from periphery import GPIO
gpio5 = GPIO(163, "in")
