Access Outer Class variables from Inner Class
Hi everyone!
I want to access the Outer Class variables from the Inner Class, but I get an error (see below).
I have this code that illustrates what I'm trying to do:
.ino
class OuterClass{
  public:
    OuterClass(){}
    void setup(char* Item){_item = Item;}
    class InnerClass{
      public:
        InnerClass(int Index){_index = Index;}
        int print() {Serial.println(_item[_index]);}
      private:
        int _index;
    InnerClass item(int Index){}
    private:
      char* _item;
OuterClass class1;
char myItem[] = "One item";
void setup(){
  class1.setup((char*)myItem);
  class1.item(1).print();
void loop(){}
I'm getting this error:
Class.ino: In member function 'int OuterClass::InnerClass::print()':
Class:16: error: invalid use of non-static data member 'OuterClass::_item'
Class:9: error: from this location
I tried to use a static class, friend class, declare it outside the Outer Class, but I get more and different errors.
How can I do this?
Nested classes cause all kinds of issues. Why do you insist on doing that?
Why can't the two classes be defined at the same level?
I want to access in a structure like this:
If I defined in the same level, I would have to declare it. The way above is more pratical.
And now I'm trying to make this work, as it's a good knowledge.
But if it there difficult problems, I will think in another method.
So? Why is that a problem?
I've stared at your code for a while now, and can't work out what you are doing.
What are you attempting to do here?
