Access to data in PROGMEM structure (two dimensional)
I have a problem,
In a .h file, a PROGMEM structure is define.
A complete example :
typedef uint8_t VT_PSTYLE;
#define VT_PSTYLE_TEXT_LEN 4
const ValueTitle<VT_PSTYLE, VT_PSTYLE_TEXT_LEN> PStyleTitles PROGMEM =
{0x21, {‘U’,‘s’,‘1’,0} },
{0x22, {‘U’,‘s’,‘2’,0} },
{0x23, {‘U’,‘s’,‘3’,0} },
{0x81, {‘S’,‘t’,‘d’,0} },
{0x82, {‘P’,‘r’,‘t’,0} },
{0x83, {‘L’,‘n’,‘d’,0} },
{0x84, {‘N’,‘t’,‘l’,0} },
{0x85, {‘F’,‘t’,‘h’,0} },
{0x86, {‘M’,‘o’,‘n’,0} }
#define VT_PSTYLE_COUNT sizeof(PStyleTitles) / (sizeof(VT_PSTYLE) + VT_PSTYLE_TEXT_LEN)
I have an input string data is “Lnd”
I want find the hexa value corresponding to “Lnd” ?
And if possible, I want find the index in the list (example position 6 in the list) ?
I have search on google and forum for help with PROGMEM but all example is for one dimensional array, but in this case is a two dimensional array.
Have you an example based on this array, to acces of the data of the first column by a request on the second column ?
Many thanks by advance,
Regards ThierryD
What is the definition of the ValueTitle template?
this is the template :
template <class ValueType, const uint8_t TitleSize>
struct ValueTitle
ValueType value;
const char title[TitleSize];
Help me, please ...
So you have a string in PROGMEM and you want to compare it to a string in SRAM. I think the strcmp_P(sram, progmem) will do that. I think the code would look something like this:
unsigned char lookupValue(char *t) {
  for (int i=0; i< VT_PSTYLE_COUNT; i++)
    if (strcmp_P(t, &PStyleTitles[i].title) == 0)
      return pgm_read_byte_near(&PStyleTitles[i].value);
  return 0;  // If no match is found
Hi John,
many many thanks,
that’s the good way (I am sure),
but I have an error and I am not a good user of pointer and strcmp.
For use your code I write :
char S = lookupValue("Lnd");
Serial.println(S);
But I have an error :
NKRemote.cpp: In function ‘unsigned char lookupValue(char*)’:
NKRemote:438: error: cannot convert ‘const char ()[4]’ to 'const prog_char’ for argument ‘2’ to ‘int strcmp_P(const char*, const prog_char*)’
I don’t now why
For test, I have use this (and that’s works fine for read all value):
void lookupValue() {
      Serial.println(pgm_read_byte_near(&PStyleTitles[i].value));
And I get all the list in the Serial Monitor (That’s good for the moment)
But if I want to get the title with :
Serial.println((String)pgm_read_word(&PStyleTitles[ i ].title));
or Serial.println((char*)PStyleTitles[ i ].title);
I have not the title.
If I read the title in a string, I can use other method to compare it with a reference string and get the value and the index.
Can you help me ?
You are only reading two bytes ( pgm_read_word )
The serial library has support for progmem strings:
Serial.println( ( __FlashStringHelper* ) &PStyleTitles[ i ].title );
Or if you want the data yourself you can use strcpy_P to retrieve the text to sram.
Many thanks for your help,
the code
works very fine.
But if I want to store the result in a string (not the serial port), Have you an example with strcpy_P ?
I am not a good user of pointer (I work, I work, ...) Thanks
Maybe something like that?
strcpy_P( buffer, (PGM_P)pgm_read_word( &(PStyleTitles[ i ].title) ) );
Many many thanks to you two for your help.
I have now all solution for works.
for read the tilte in a string I have use that :
char bufferX[4];
strcpy_P(bufferX, PStyleTitles[i].title);
Serial.println(bufferX);
For all users, the complete test code to get the title and the value (and i is the index) :
    char bufferX[4];
Many thanks again
Problem is solved
You will have problems with that:
Use the thing I posted, I'm not sure it's the correct way to do it, but I know it works perfect.
A little end question.
if my value is stored like this : 0x000493E0 or 0xFFFFFFFF
the line Serial.println(pgm_read_byte_near(&PStyleTitles*.value)); can't read this because byte_near is one byte.* What pgm_read ... I do to use for read a data who is 0xFFFFFFFF Thanks
I have found (search in Google)
it is
Serial.println(pgm_read_dword(&ShutterSpeedTitles[i].value));
A new end little question (the very end)
This function works fine
    char bufferX[4];
but if now I want to pass parameters to use the same function for many list (same structure)
what is the best to pass thePStyleTitles in parameters ?
It is to do that :
void lookupValue(int LIST_COUNT, int TEXT_LEN, ????????) {
  for (int i=0; i< LIST_COUNT; i++)
    char bufferX[TEXT_LEN];
    strcpy_P(bufferX, ????????[i].title);
    Serial.println(pgm_read_byte_near(&????????[i].value));
The ??? is my problem to transfert pointer and it is the list.
Use a pointer to pass the array:
void lookupValue(int LIST_COUNT, int TEXT_LEN, ValueTitle<VT_PSTYLE, VT_PSTYLE_TEXT_LEN> *v_Ptr ) {
    strcpy_P(bufferX, v_Ptr[i].title);
    Serial.println(pgm_read_byte_near(&v_Ptr[i].value));
Or for ease of use with the template type:
typedef ValueTitle<VT_PSTYLE, VT_PSTYLE_TEXT_LEN> VTT;
void lookupValue(int LIST_COUNT, int TEXT_LEN, VTT *v_Ptr ) {
Many thanks at all for your answers
Regards.
