access to webpage library description
Hello.
I am going to start with a new project and this is the first time I am going to use Arduino. I will like someone to redirect me to anywhere where every function hold by the platform is described, such as it occurs with python.
The problema is that for example I do not find a section where all the analog functions are described, so I can choose the ones I need. I put analog LIbrary as an example, buy configuration library is also necessary.
I have gone to Atmel datasheet and as I knew the description is for programming the controller in assembler.
Thanks to anyone.
There are only two, analogRead() and analogWrite(), and analogWrite() really should be called something else as it does nothing with analog pins.
I'm not sure I understand this. There is not an analog library for the Arduino that I am aware of. Nor am I aware of a "configuration library".
PaulS:
Yes, I mean that. The problem is that because I have never use Arduino, I do not know where to look. All my works with controllers has been done in assembler, and with the datasheet of the microcontroller was enough.
I need to know where to acces for config mode and things like that (I have seen that the sentence I wrote: " put analog LIbrary as an example, buy configuration library is also necessary." Buy has to be changed for but (sorry because I work on spanish computer and sometimes it correct me the words badly)). What I need is where to get information. I look on learning window in arduino.cc webpage but is not enough. That is why I put python as example:
https://docs.python.org/2/library/
Thanks
