I'm trying to access a variable that is declared and defined within a member function of a class, contained within a CPP file. I need to be able to see what the value of "eType" is every time parseEvent() is called. I've tried a number of things such as:
- Moving eType to the MIDIFile.h header file
- Declaring eType as extern and declare/defining it within the Arduino IDE
- Creating a function within the MFTrack class that returns the value of eType and calling said function in Arduino IDE
All of these attempt produced errors. After spending several hours on this, I figure I need to seek out some help. I've included excerpts of the most important parts of the code.
Library: Google Code Archive - Long-term storage for Google Code Project Hosting.
MIDIFile.cpp Contains "eType" and getNextEvent(MIDIFile *mf, uint32_t elapsedTime);
void MFTrack::parseEvent(MIDIFile *mf)
// process the event from the physical file
uint8_t eType;
uint32_t eLen, mLen;
sysex_event sev; // used for sysex callback function
// now we have to process this event
eType = mf->_fd.read();
switch (eType)
// ---------------------------- MIDI
// midi_event = any MIDI channel message, including running status
// Midi events (status bytes 0x8n - 0xEn) The standard Channel MIDI messages, where 'n' is the MIDI channel (0 - 15).
// This status byte will be followed by 1 or 2 data bytes, as is usual for the particular MIDI message.
// Any valid Channel MIDI message can be included in a MIDI file.
case 0x80 ... 0xBf: // MIDI message with 2 parameters
case 0xe0 ... 0xef:
_mev.size = 3;
_mev.data[0] = eType;
_mev.channel = _mev.data[0] & 0xf; // mask off the channel
_mev.data[0] = _mev.data[0] & 0xf0; // just the command byte
_mev.data[1] = mf->_fd.read();
_mev.data[2] = mf->_fd.read();
DUMPS("[MID2] Ch: ");
DUMP(_mev.channel);
DUMPS(" Data: ");
DUMPX(_mev.data[0]);
DUMP(' ');
DUMPX(_mev.data[1]);
DUMP(' ');
DUMPX(_mev.data[2]);
#if !DUMP_DATA
if (mf->_midiHandler != NULL)
(mf->_midiHandler)(&_mev);
#endif // !DUMP_DATA
bool MFTrack::getNextEvent(MIDIFile *mf, uint32_t elapsedTime)
// track_event = <time:v> + [<midi_event> | <meta_event> | <sysex_event>]
uint32_t deltaT, elapsedTicks;
// is there anything to process?
if (_endOfTrack)
return(false);
// move the file pointer to where we left off
mf->_fd.seekSet(_startOffset+_currOffset);
// work out new total elapsed time
_elapsedTimeTotal += elapsedTime;
elapsedTicks = _elapsedTimeTotal / mf->getMicrosecondDelta();
// Get the DeltaT from the file in order to see if enough ticks have
// passed for the event to be active. If not, just return without
// saving the file pointer and we will go back to the same spot next time.
deltaT = readVarLen(&mf->_fd);
if (elapsedTicks < deltaT)
return(false);
// Adjust the total elapsed time. Note use of actual DeltaT to avoid
// accumulation of errors as we only check for elaspedTime being >= ticks,
// giving positive biased errors every time.
_elapsedTimeTotal -= (deltaT * mf->getMicrosecondDelta());
DUMPS("\ndT: ");
DUMP(deltaT);
DUMP("\tET: ");
DUMP(elapsedTicks);
DUMP('\t');
parseEvent(mf);
// remember the offset for next time
_currOffset = mf->_fd.curPosition() - _startOffset;
return(true);
MIDIFile.cpp Contains the getNextEvent() function
**boolean MIDIFile::getNextEvent(void)
uint32_t elapsedTime;
uint8_t n;
// if we are paused we are paused!
if (_paused) return false;
// sync start all the tracks if we need to
if (!_syncAtStart)
synchTracks();
_syncAtStart = true;
// check if enough time has passed for a MIDI tick
elapsedTime = micros() - _lastEventCheckTime;
if (elapsedTime < _microsecondDelta)
return false;
_lastEventCheckTime = micros(); // save for next round of checks
if (_format != 0) DUMPS("\n-- TRK ");
#if TRACK_PRIORITY
// process all events from each track first - TRACK PRIORITY
for (uint8_t i = 0; i < _trackCount; i++)
if (_format != 0) DUMPX(i);
// Limit n to be a sensible number of events in the loop counter
// When there are no more events, just break out
// Other than the first event, the other have an elapsed time of 0 (ie occur simultaneously)
for (n=0; n < 100; n++)
if (!_track[i].getNextEvent(this, (n==0 ? elapsedTime : 0)))
if ((n > 0) && (_format != 0))
DUMPS("\n-- TRK ");
#else // EVENT_PRIORITY**
**__ <strong>__**Arduino Code:**__</strong> __**
**void loop(void)
int err;
for (uint8_t i=0; i<ARRAY_SIZE(tuneList); i++)
// reset LEDs
digitalWrite(READY_LED, LOW);
digitalWrite(SD_ERROR_LED, LOW);
// use the next file name and play it
SMF.setFilename(tuneList[i]);
err = SMF.load();
if (err != -1)
DEBUG("\nSMF load Error ");
DEBUG(err);
digitalWrite(SMF_ERROR_LED, HIGH);
delay(WAIT_DELAY);
// play the file
while (!SMF.isEOF())
if (SMF.getNextEvent())
tickMetronome();
// done with this one
SMF.close();
midiSilence();
// signal finsh LED with a dignified pause
digitalWrite(READY_LED, HIGH);
delay(WAIT_DELAY);
__```**__
