I'm using an Arduino Uno R3 to talk to some I2C devices. I've allocated a global pointer to my Wire instance and this works great. I have great I2C communication. I added an interrupt, and the interrupt works great. Inside the interrupt I can manipulate global variables just fine (++, --, etc..). Now my goal is when I receive the interrupt, I need to retrieve some data over the I2C bus, to see why my interrupt happened. However, when I access my global pointer to my Wire instance, the Arduino hangs. I'm thinking the problem is that the Wire library also uses interrupts, and this might be my problem... Is there any way around this? Would a different Arduino board allow me to use I2C from inside an interrupt routine?
You can set a flag variable in the interrupt routine - the variable must be global and declared volatile. In the loop function you can continuously check for the flag to be set. Once it is set, clear it and access the I2C bus.
Pete
I'll give that a shot, I'm afraid I don't have enough time to do that though. I'm using an IO Expander chip, this gives me 8 digital inputs. When any pin changes level, I get an interrupt. The states don't latch, so at that instant I need to capture the state of all of the pins. The levels may only be changed for a few milliseconds, so if I don't get there in time I will miss the state. This is why I was hoping to read the state immediately from the interrupt routine. I'll try your suggestion, maybe I can make it happen fast enough. Thanks for the idea. I'm into hour 12 today, so even simple things are becoming complicated; time for a nap!
I2C isn't the best protocol in that situation. At 400kHz it will take on the order of 8 milliseconds to receive a response even if you could respond to the interrupt immediately. If my suggestion doesn't work fast enough you might have to rethink the overall design.
Pete
HardwareInFL:
Which chip?
It’s the PCA95544N:
So far it seems to work as-advertised.
el_supremo:
I2C isn't the best protocol in that situation. At 400kHz it will take on the order of 8 milliseconds to receive a response even if you could respond to the interrupt immediately. If my suggestion doesn't work fast enough you might have to rethink the overall design.Pete
Yes you have a good point... I unfortunately don't have a scope here to time exactly how long my input state lasts, but I do know that I have to debounce it somehow and I'm thinking of using this chip:
If my input state lasts long enough to work with the debouncer, then hopefully the debouncer will hold its output value long enough to give me plenty of time to read it. I'll find out shortly.
HardwareInFL:
If you can get all 8 inputs on the same AVR Port then you can read them all at once with a Port Read. With a MEGA you have clear ports by default. With an UNO... not so easy if possible at all, better to use 2 Ports of 4 bits each.
Look up Port Manipulation on this site.
Thanks for the suggestion, the port manipulation stuff looks interesting. For this particular project, we're fixed on I2C and an Uno board (executive decision from above). We're going to have several of these port expanders, both for more I/O and to reduce the wiring required, so unfortunately wiring direct to the Arduino isn't possible. Our device will have a lot of modular hardware, many inputs and many outputs, and with I2C we only need to run 2 wires to each module. We will be instructing hardware to do things, and receiving interrupts when events happen. We have to detect the event and then control the hardware accordingly. It worked great wired directly to a Mega 256, so now we're moving to the Uno to reduce per-unit costs. It looks good on paper anyway.. 8)
HardwareInFL:
To reduce per-unit cost you should use a stand-alone AVR chip (like a 328 or 1284) possibly running on internal oscillator. The external oscillator on the UNO uses 2 pins that would let you have 8 bits on one port, but I see that you don't need that.
Port expanders? I hope they're as cheap as shift registers ;^) or actually are shift registers, 2 or 3 for a buck. The kind I get are SPI bus which is 4 wires but 2 MB/sec fast (AVR running 16MHz). It's possible to write a line of those over 10,000x a second. There are bi-directional shift registers but for code simplicity I would go with daisy-chained shift register outputs on the one hardware SPI bus and perhaps inputs daisy-chained on soft-SPI.
Port expanders are far more than just shift registers:
- They are bi-directional, just like a real port - set pins to be input or output.
- Often they also provide internal pull-up resistors, just like a real port.
- They usually provide interrupt-on-change so when an input changes state it triggers an interrupt signal (which is exactly what the OP is doing).
You can't do those with shift registers, which is why you pay more for them.
If you want to use I2C from within an interrupt routine you will have to write your own (or find one if you're lucky) I2C library that doesn't use interrupts in its operation. The default I2C uses interrupts to manage the transfer of data from its internal buffer and the outside world and back again. This gives a smoother transfer with no blocking happening while the transfer goes on. If you write it to access the I2C registers directly and block waiting for each byte to transfer then it might be possible to do it inside the interrupt routine.
However, that is still not advised, as an interrupt routine should be kept as brief as possible, and doing blocking I2C inside the interrupt routine could get messy with interrupt collisions etc.
I have bi-directional shift registers, but they're surface mount. The port extenders are superior anyway. I'd just wonder about price since a small AVR might cost less.
ATtiny2313A-PU, 2k flash, 128 bytes RAM, 18 I/O pins for 95 CENTS at Futurlec.
But... do we have core data for programming them?
I use the MCP23017 a lot (also comes in the MCP23S17 SPI version for those that need greater throughput). Gives 16 IO channels, 2 interrupt signals, pull-up resistors, etc. Costs 95p at Farnell. - and no special firmware needed to get it going - just drop it in the circuit and use pre-existing Arduino libraries at the bus master end. The extra 30p you spend on the device you save on not having to spend a week writing the firmware to emulate the port expander.
Which bi-directional shift registers do you use? Can they be a mixture of input and output pins, or do they all have to be the same direction?
Got, not used. Got surface mount by mistake and I'm bad enough soldering pins.
What I should have bought are the 74F299 in PDIP 20-pin, just over US$1 ea.
If you're going to use enough of something like in a product, a bit of code is no big deal.
Those shift registers can either be all input or all output - you can’t mix and match like you can with a port expander. Useful bits of kit though, shift registers, for things like driving LED displays and such.
And for getting simultaneous i/o, and as pin multipliers....
Some time I should start collecting logic gates and flip-flops.
majenko:
I'm pretty sure this library doesn't use interrupts:
It only acts as a master, not slave. It also uses less memory then wire.h.
Use the interrupt signal from the port expander to take a snapshot of the bus with an octal D flip/flop or bus latch… Note it in the interrupt and then go service the bus latch later.
Doc
Some other thoughts:
- Switch to SPI so your data transfer times are reduced.
- Consider a "slave" device that provides the IO facilities and services the interrupts locally then only sends the results back to the master.
- Use a combination of shift register and external circuitry to create your own IoC signal and then perform a single byte shift-in. (Somewhat complex and bulky, but fun to do - great for learning about flip-flop circuitry).
