accessing arduino through at&t uverse router
I have been trying to access my arduino outside of my local network for a while now. I think i’ve set port forwards that direct to my arduino’s ip address but i can’t seem to get it working.
I can access it locally via http://192.168.1.10:85/. I’ve set up port 85 to forward to the arduino’s ip at port 85. I know my router’s external ip. It’s 99.70.245.xxx. I tried to go to http://99.70.245.xxx:85 on my phone(outside my local network) but i can’t connect.
Here are a couple pics of me setting up the port forward.
http://imgur.com/eaN7aZQ
http://imgur.com/qGlhWL0
here is my arduino code. I tried manually setting the gateway and subnet, but that didn’t work either. Anybody have any suggestions?
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,1, 10);
 //byte gateway[] = { 99, 40, 214, 1 }; //Manual setup only
// byte subnet[] = { 255, 255, 252, 0 }; //Manual setup only
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(85);
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
  // listen for incoming clients
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println("Connnection: close");
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
                    // add a meta refresh tag, so the browser pulls again every 5 seconds:
       //   client.println("<meta http-equiv=\"refresh\" content=\"5\">");
          // output the value of each analog input pin
          for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
            int sensorReading = analogRead(analogChannel);
            client.print("analog input ");
            client.print(analogChannel);
            client.print(" is ");
            client.print(sensorReading);
            client.println("
          client.println("</html>");
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disonnected");
