Accessing array objects by reference out of array
My title doesn't do a good job of explaining what I'm trying to do, which has likely hindered my ability to find a solution by searching.
I have a group of object instances, which are also in an array. I wish to access these instances by reference both while iterating through the array and individually.
This code is a simplified version of my problem:
struct Foo
 int bar;
Foo Foo1;
Foo Foo2;
Foo Foo3;
Foo FooArray[3] = {Foo1, Foo2, Foo3};
 Foo1.bar = 1;
 Foo2.bar = 2;
 Foo3.bar = 3;
 for(byte i=0; i<3; i++)
   FooArray[i].bar += 1;
  Serial.println(FooArray[i].bar);
 Serial.println(Foo1.bar);
 Serial.println(Foo2.bar);
 Serial.println(Foo3.bar);
 delay(2000);
What I would like to achieve is that the FooArray*.bar += 1; also affects the bar property of each instance when accessed directly.*
Well, there are two approaches, structs or classes. Your code declares Foo as a struct and proceeds to use it as a class :slight_smile:
So let's look at both possibilites, first as structures:
struct Foo
 int bar;
struct Foo Foo1;
struct Foo Foo2;
struct Foo Foo3;
struct Foo *FooArray[3] = {&Foo1, &Foo2, &Foo3};
 Foo1.bar = 1;
 Foo2.bar = 2;
 Foo3.bar = 3;
   FooArray[i]->bar += 1;
  Serial.println(FooArray[i]->bar);
 delay(2000);
Now with Foo as a class:
class Foo
public:
 int bar;
Foo Foo1;
Foo Foo2;
Foo Foo3;
 Foo1.bar = 1;
 Foo2.bar = 2;
 Foo3.bar = 3;
 delay(2000);
Check out our new shield: http://www.ruggedcircuits.com/html/gadget_shield.html
Thank you!
This is my first time working in C++ and I'm clearly struggling with the syntax. My use of structs was an attempt to simplify my example; my code uses classes form a library I'm writing.
Your example gave me the building blocks to achieve what I'm really trying to do, which is more accurately represented by the following example:
class Foo
public:
 int bar;
Foo Foo1;
Foo Foo2;
Foo Foo3;
void barPlus(Foo &f)
  f.bar += f.bar;
 Foo1.bar = 1;
 Foo2.bar = 2;
 Foo3.bar = 3;
   barPlus(*FooArray[i]);
 delay(2000);
Hey there.
You may be surprised to know that in C++ the only difference between structs and classes is that in a class, anything is by default is declared as "private"- That's it!
References are good to know: However, I don't think that you are using them right. A reference is an automatic "call by reference", so that you don't have to have a list of pointers.
(See Code to the right)
class Foo
public:
 int bar;
Foo FooArray[3];
//use Foo at address...
  f.bar += f.bar;
 FooArray[0].bar = 1;
 FooArray[1].bar = 2;
 FooArray[2].bar = 3;
   //Passes address of class
   // (&FooArray[i])
   barPlus(FooArray[i]);
 delay(2000);
InvalidApple, your version appears cleaner, but it loses one of the original requirements; I need to address each instance by its own variable name, not just by its array index.
p.s. hi from Melbourne :wink:
Hey there;
I'd then say to just use pointers. (opinion as fact...)
:slight_smile:
