I am using IR receiver coding based on changes to the IR libraries. The new code is
#include <Arduino.h>
#include <IRremote.h>
#define IR_PIN 11
pinMode(LED_BUILTIN, OUTPUT);
pinMode(8, OUTPUT);
// digitalWrite(Led-pin, HIGH);
IrReceiver.begin(IR_PIN, ENABLE_LED_FEEDBACK);
delay(3000);
digitalWrite(8, LOW);
if (IrReceiver.decode()) {
digitalWrite(8, HIGH);
IrReceiver.printIRResultShort(&Serial);
Serial.println("next print? ");
IrReceiver.printIRResultAsCVariables(&Serial);
Serial.println("----");
Serial.println("--- +++ ---");
// IrReceiver.printIRResultsShort(&value);
delay(3000);
// if(Protocol == "NEC") {Serial.println(Protocol)};
IrReceiver.resume();
I hope to access the individual fileds in the IR Receiver output. This lines in my code --- " IrReceiver.printIRResultShort(&Serial);" --- produce printing lines showing several fields --- names and data.
"Protocol=NEC Address=0xA3 Command=0x99 Raw-Data=0x66995CA3 32 bits LSB first
next print?
uint16_t address = 0xA3;
uint16_t command = 0x99;
uint32_t data = 0x66995CA3;Protocol=NEC Address=0xA3 Command=0x99 Raw-Data=0x66995CA3 32 bits LSB first
I want to access one of these fields ("Raw-Data)" to test for data value higher than 0x66000000 or in that range, How do I code instructions to access that particular field?
Tom Kane / Vancouver, B.C., Canada
