Accessing serial data stored in a buffer using a char pointer ?
Hi there,
My arduino application requires the ability to read in various commands on the arduino UART, some comprising of letters i.e. “abcON”, “abcOFF” and some alphanumeric, “sonicRead850”.
I have discovered code examples as described here: Gammon Forum : Electronics : Microprocessors : How to process incoming serial data without blocking and found them to be of great help.
// how much serial data we expect before a newline
const unsigned int MAX_INPUT = 50;    // the const variable qualifier basically makes the variable read-only
void setup ()
} // end of setup
// here to process incoming serial data after a terminator received
void process_data (char * data)    //function called process_data.  - data is declared as a pointer of type char,
    Serial.println (data);      // i think this works as process_data is an array which is basically a dereference to the first value of the array
  }  // end of process_data
void loop()  //called every clock cycle or whatever is used to determine it !!
static char input_line [MAX_INPUT];    //array size 50 called input_line, NB:note static pre qualifier !!!local variables are created & destroyed every time a function is called
static unsigned int input_pos = 0;     //array index again note static qualifier, static variables persist beyond the function call & are initialised the first time the function is called
static boolean valid_Flag = false;
  if (Serial.available () > 0)         // when bytes are in the hardware buffer we run this loop,
      char inByte = Serial.read ();
      if (inByte == '<')               // watch for '<' indicating start of valid command & set flag true
        //Serial.println(inByte);
        valid_Flag = true;
        if (valid_Flag)                // flag lets us process switch statement if true!
          switch (inByte)
            case '>':   // end of text
            input_line [input_pos++] = inByte;
            input_line [input_pos] = 0;  // write terminating null byte
            //input_line [0] = ' ';
            // terminator reached! process input_line here ...
            process_data (input_line);
            // reset buffer for next time
            input_pos = 0;  // reset index to 0
            valid_Flag = false;
            case '\r':   // discard carriage return
            default:
            // keep adding if not full ... allow for terminating null byte
            if (input_pos < (MAX_INPUT - 1)) //-1 allows for null terminator, if input_pos index is less 49
              input_line [input_pos++] = inByte;  //write serial read inbyte to input_line and increment input_pos (index)
          }  // end of switch
        }  // end of if valid command '<'
  }  // end of incoming data
  // do other stuff here like testing digital input (button presses) ...
}  // end of loop
comments are just to help me understand, I have modifyed the original code as I want to ensure that only commands enclosed with < > tags will be accepted, the original code runs the following function to serial.print the data,
  // for now just display it
The char array being pointed to by a char pointer data, I am confused as how to manipulate / parse for numerials or strings using the pointer data.
Serial.print(data) can access the buffer, but when I try the following
char x = *data;
  int i=0;
  while (isdigit(x))
     i++;
     x++;
It just prints 0, I think that x = *data; is just dereferencing position 0 if the char array thus ‘<’ character, I am unsure how to increment and to parse this data, any suggestions would be most welcome.
regards
Denis
well that is not going to work.
You read a character, check if it is <, and then go and look at whether it is something else.
You can set a char * to the start of a char array:
char buffer[ 32 ]; char *buf = buffer;
You can index the pointer: buf++; // move 1 byte to the next char, if it was an int pointer it would move 2 bytes to the next int buf--; // you can go back
You can do pointer math: buf += 8; buf -= 2;
You can use string (not C++ String object but C string.h) commands to set pointers to say... find a character withing a string or a string within a string or to parse a string.
There's too many to list here when they're listed and explained elsewhere: http://www.nongnu.org/avr-libc/user-manual/group__avr__string.html
You can treat pointers as variable memory addresses.
A valid C string ends with a NULL ( == 0 ) character.
Hi there, thanks for your suggestions, I have a grasp of what you outline
However in my case the pointer resides in a function "process_data()" called from, "loop()" where the char array, "static char input_line [MAX_INPUT" also resides
    char * buff = buffer; // should buffer now = memory location 0 in char array input_line[] ?
I guess I am wondering if the fact that the pointer resides within a function called by loop() & that char array is also in function loop() is this preventing me from accessing (dereferencing) indvidual memory locations within the array.
Thanks for the reference for the standard c string commands, they look much better for parsing my data
regards
Ok, looked at GoForSmoke’s post again and tried the following,
    char * buffer = data;
    buffer = buffer +3;
    Serial.print("how many digits ");
    Serial.println(buffer);
In serial monitor I enter <123456789>
output
how many digits 3456789>
<123456789>
so cool buffer shifted 3 places,
tks GoForSmoke !
And a Happy Saint Patrick's Weekend to ya! Drink a Jameson's for me, willya?
One thing, just to make sure as I'm not. Make buffer[], and any arrays and variables referred to by different functions as global by defining them right up near the top above setup() even. A static inside loop() should not be visible outside loop().
Tks for the tip GoForSmoke !
I think I will manage a "drop" of Jameson or Paddy over the weekend just for yourself ;)
And I'll toast ya with ale next time I'm down at Big Jim's. It's cups there but at least it's ale.
