So I am trying to read in a matrix of values from an SD card, and I am successfully doing so. Ideally, I would do this reading in of the matrix via a function called in the setup(), and be able to manipulate the data inside of the matrix in loop(). However, I am uncertain how to allow the matrix to be "seen" by setup() and loop(), as the matrix is defined within my ReadCardInfo function.
Normally I would just define the matrix before the setup() part in order to make the variable a global variable, but unfortunately I only know the size of the matrix when I open the SD card and read in the first line (this first line contains the dimensions). Alternatively I would just make the matrix be an output to the function, but I can't seem to get the function to allow matrix outputs.
So, any suggestions on how to allow this matrix to be seen?
Here is the code as I have it so far, which reads in an SD card and saves it into the matrix I want to access called myMatrix:
#include <SD.h>
const int chipSelect = 4;
char fileName[] = "circlel.txt";
void setup(){
//Read in the SD card info
ReadCardInfo(fileName);
void loop(){
void ReadCardInfo(const char *fileName)
Serial.print("Initializing Card");
Serial.println();
//Make sure the card is valid
if (!SD.begin(chipSelect))
Serial.println("initialization failed");
while(1);
Serial.println("Card initialized!");
//Read in the file
File myText = SD.open(fileName);
//Make sure the file is valid
if (myText){
Serial.println("good");
else{
Serial.println("bad");
while(1);
//Get the number of rows and columns of the matrix (this will always be the first line of the text file)
int rowNum = myText.parseInt();
int colNum = myText.parseInt();
//Initialize the matrix
float myMatrix[rowNum][colNum];
if (myText){
if (myText.available()){
//For each row and column,
for (int i=0; i < rowNum; i++){
for (int j=0; j < colNum; j++){
//Read in the next float
float c = myText.parseFloat();
//Save that value into the matrix
myMatrix[i][j] = c;
myText.close();
Serial.println("Done");
//For testing purposes, print the contents of the SD card to Serial
for (int i=0; i< rowNum; i++){
Serial.print(myMatrix[i][j]);
Serial.print(" ");
Serial.println("");
