Accessing variables defined in .CPP file of a library
I'm building a DMX controller and am using the DmxSimple library (found here). I would like my controller to be able to save and recall presets for the entire DMX buffer (up to 512 8-bit values).
DmxSimple.CPP defines an array called dmxBuffer[DMX_SIZE] that I would like to be able to read and write to in my main arduino code:
volatile uint8_t dmxBuffer[DMX_SIZE];
But trying to access this variable gives an error:
Serial.println(dmxBuffer(1));
SerialToDmx:35: error: 'dmxBuffer' was not declared in this scope
Is there a way to access this array from within the Arduino code?
Here is my arduino code:
#include <DmxSimple.h>
  Serial.println("SerialToDmx ready");
  Serial.println("Syntax:");
  Serial.println(" 123c : use DMX channel 123");
  Serial.println(" 45w  : set current channel to value 45");
int value = 0;
int channel;
  int c;
  while(!Serial.available());
  c = Serial.read();
  if ((c>='0') && (c<='9')) {
    value = 10*value + c - '0';
    if (c=='c') channel = value;
    else if (c=='w') {
      DmxSimple.write(channel, value);
    value = 0;
Here is dmxSimple.CPP:
 * DmxSimple - A simple interface to DMX.
 * Copyright (c) 2008-2009 Peter Knight, Tinker.it! All rights reserved.
#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#include "pins_arduino.h"
#include "wiring.h"
#include "DmxSimple.h"
/** dmxBuffer contains a software copy of all the DMX channels.
static uint16_t dmxMax = 16; /* Default to sending the first 16 channels */
static uint8_t dmxStarted = 0;
static uint16_t dmxState = 0;
static volatile uint8_t *dmxPort;
static uint8_t dmxBit = 0;
static uint8_t dmxPin = 3; // Defaults to output on pin 3 to support Tinker.it! DMX shield
void dmxBegin();
void dmxEnd();
void dmxSendByte(volatile uint8_t);
void dmxWrite(int,uint8_t);
void dmxMaxChannel(int);
/* TIMER2 has a different register mapping on the ATmega8.
 * The modern chips (168, 328P, 1280) use identical mappings.
#if defined(__AVR_ATmega168__) || defined(__AVR_ATmega168P__) || defined(__AVR_ATmega328P__) || defined(__AVR_ATmega1280__)
#define TIMER2_INTERRUPT_ENABLE() TIMSK2 |= _BV(TOIE2)
#define TIMER2_INTERRUPT_DISABLE() TIMSK2 &= ~_BV(TOIE2)
#elif defined(__AVR_ATmega8__)
#define TIMER2_INTERRUPT_ENABLE() TIMSK |= _BV(TOIE2)
#define TIMER2_INTERRUPT_DISABLE() TIMSK &= ~_BV(TOIE2)
#else
/* Produce an appropriate message to aid error reporting on nonstandard
 * platforms such as Teensy.
#warning "DmxSimple does not support this CPU"
#endif
/** Initialise the DMX engine
void dmxBegin()
  dmxStarted = 1;
  // Set up port pointers for interrupt routine
  dmxPort = portOutputRegister(digitalPinToPort(dmxPin));
  dmxBit = digitalPinToBitMask(dmxPin);
  // Set DMX pin to output
  pinMode(dmxPin,OUTPUT);
  // Initialise DMX frame interrupt
  // Presume Arduino has already set Timer2 to 64 prescaler,
  // Phase correct PWM mode
  // So the overflow triggers every 64*510 clock cycles
  // Which is 510 DMX bit periods at 16MHz,
  //          255 DMX bit periods at 8MHz,
  //          637 DMX bit periods at 20MHz
  TIMER2_INTERRUPT_ENABLE();
/** Stop the DMX engine
 * Turns off the DMX interrupt routine
void dmxEnd()
  TIMER2_INTERRUPT_DISABLE();
  dmxStarted = 0;
  dmxMax = 0;
/** Transmit a complete DMX byte
 * We have no serial port for DMX, so everything is timed using an exact
 * number of instruction cycles.
 * Really suggest you don't touch this function.
void dmxSendByte(volatile uint8_t value)
  uint8_t bitCount, delCount;
  __asm__ volatile (
    "cli\n"
    "ld __tmp_reg__,%a[dmxPort]\n"
    "and __tmp_reg__,%[outMask]\n"
    "st %a[dmxPort],__tmp_reg__\n"
    "ldi %[bitCount],11\n" // 11 bit intervals per transmitted byte
    "rjmp bitLoop%=\n"     // Delay 2 clock cycles.
  "bitLoop%=:\n"\
    "ldi %[delCount],%[delCountVal]\n"
  "delLoop%=:\n"
    "nop\n"
    "dec %[delCount]\n"
    "brne delLoop%=\n"
    "sec\n"
    "ror %[value]\n"
    "brcc sendzero%=\n"
    "or __tmp_reg__,%[outBit]\n"
  "sendzero%=:\n"
    "dec %[bitCount]\n"
    "brne bitLoop%=\n"
    "sei\n"
      [bitCount] "=&d" (bitCount),
      [delCount] "=&d" (delCount)
      [dmxPort] "e" (dmxPort),
      [outMask] "r" (~dmxBit),
      [outBit] "r" (dmxBit),
      [delCountVal] "M" (F_CPU/1000000-3),
      [value] "r" (value)
/** DmxSimple interrupt routine
 * Transmit a chunk of DMX signal every timer overflow event.
 * The full DMX transmission takes too long, but some aspects of DMX timing
 * are flexible. This routine chunks the DMX signal, only sending as much as
 * it's time budget will allow.
 * This interrupt routine runs with interrupts enabled most of the time.
 * With extremely heavy interrupt loads, it could conceivably interrupt its
 * own routine, so the TIMER2 interrupt is disabled for the duration of
 * the service routine.
ISR(TIMER2_OVF_vect,ISR_NOBLOCK) {
  // Prevent this interrupt running recursively
  uint16_t bitsLeft = F_CPU / 31372; // DMX Bit periods per timer tick
  bitsLeft >>=2; // 25% CPU usage
  while (1) {
    if (dmxState == 0) {
      // Next thing to send is reset pulse and start code
      // which takes 35 bit periods
      uint8_t i;
      if (bitsLeft < 35) break;
      bitsLeft-=35;
      *dmxPort &= ~dmxBit;
      for (i=0; i<11; i++) _delay_us(8);
      *dmxPort |= dmxBit;
      _delay_us(8);
      dmxSendByte(0);
      // Now send a channel which takes 11 bit periods
      if (bitsLeft < 11) break;
      bitsLeft-=11;
      dmxSendByte(dmxBuffer[dmxState-1]);
    // Successfully completed that stage - move state machine forward
    dmxState++;
    if (dmxState > dmxMax) {
      dmxState = 0; // Send next frame
  // Enable interrupts for the next transmission chunk
void dmxWrite(int channel, uint8_t value) {
  if (!dmxStarted) dmxBegin();
  if ((channel > 0) && (channel <= DMX_SIZE)) {
    if (value<0) value=0;
    if (value>255) value=255;
    dmxMax = max((unsigned)channel, dmxMax);
    dmxBuffer[channel-1] = value;
void dmxMaxChannel(int channel) {
  if (channel <=0) {
    // End DMX transmission
    dmxEnd();
    dmxMax = 0;
    dmxMax = min(channel, DMX_SIZE);
/* C++ wrapper */
/** Set output pin
 * @param pin Output digital pin to use
void DmxSimpleClass::usePin(uint8_t pin) {
  dmxPin = pin;
  if (dmxStarted && (pin != dmxPin)) {
    dmxEnd();
    dmxBegin();
/** Set DMX maximum channel
 * @param channel The highest DMX channel to use
void DmxSimpleClass::maxChannel(int channel) {
  dmxMaxChannel(channel);
/** Write to a DMX channel
 * @param address DMX address in the range 1 - 512
void DmxSimpleClass::write(int address, uint8_t value)
	dmxWrite(address, value);
DmxSimpleClass DmxSimple;
Here is DmxSimple.H:
#ifndef DmxSimple_h
#define DmxSimple_h
#include <inttypes.h>
#if RAMEND <= 0x4FF
#define DMX_SIZE 128
#else
#define DMX_SIZE 512
#endif
class DmxSimpleClass
  public:
    void maxChannel(int);
    void write(int, uint8_t);
    void usePin(uint8_t);
extern DmxSimpleClass DmxSimple;
#endif
What about:
 Serial.println(dmxBuffer[1])
Array indices use brackets.
Though this would just print the second byte of the buffer in question... probably not what you are trying to do?
You can use the extern directive
See this and see if it can help you
That worked, adding the following line to my sketch fixed the issue:
extern volatile uint8_t dmxBuffer[DMX_SIZE];
Thanks!
