Accidently flashed ATmega16u2 usb to serial converter from arduino board
Hi Friends,
As the title says I messed up and attached the AVR programmer to the wrong ISP port ending up with the arduino bootloader on the USB/Serial chip.
Does someone has fuse and bootloader settings for this?
Ok so this was an easy one.
The chip is not read protected, so I simply read the flash from another arduino board and dumped into the blank one.
For convenience the files are attached for both a mega and an uno
Warning - This is the USB serial chip, not the arduino bootloader
ATmegaBOOT16u2_mega.hex (22.5 KB)
ATmegaBOOT16u2_uno.hex (22.5 KB)
I think these will be the same files as found in the below folder.
arduino\hardware\arduino\firmwares\atmegaxxu2\arduino-usbserial
