Hello I want to build a weather station as well as a temperature sensor in ever room in my house. I have seen several sensors that are cheap that can give +/- 5 degrees but I need higher accuracy. I dont mind paying more for them if they are accurate. It would be nice if they did temp and humidity also.
According to the manufacturer's data sheet, the DS18B20 is accurate to ±0.5°C over the range of -10°C to +85°C. You can individually calibrate each one for higher accuracy.
BME280 has both, temperature and humidity. As extra air pressure. Accuracy @ 25°C 0,5V.
The problem with most of the sensors is the distance between sensor and main board. BME280 is SPI or I2C. Not for long distances. 1 sensor with ATtiny and RS485 communication is a better choice. Or ESP8266 with WiFi (MQTT and JSON?) communication.
Let's say your house has an eight foot ceiling in each room (about 2.5 meters). Now tell me when the temperature is at floor level and the temperature is at ceiling level what the difference in degrees C or F will be? You may want to read up on air stratification or stratified air. Unless you can constantly keep the sir in any room moving you face that little problem.
Next in keeping things somewhat inexpensive and accurate to your specification of 0.5 degrees you don't mention C or F but we can assume degrees C.
Last but not least is if you choose a Dallas Temperature DS18B29 they are a good one wire temperature sensor. I am not sure how well that one wire will work out depending on distance? I guess it depends on distance from every room in your house?
Thanks for all of the replies. I am in the US so we use Fahrenheit. Each room will have a wireless transmitter (I am currently looking at esp32 and xbee).
I dont mind paying more for a more accurate sensor
Then I would run with the Dallas Temperature 18B20 sensors. Since each sensor will have its own transmitter wire runs are not a concern. Just place the sensors at a level you are concerned and run with it. That should get you what you want. The sensors I have bought online are actually not bad.
