acelermetor count goes down after 1 peak
ay
Active today
Viewed 5 times
0
I am using a Wemos D1 Mini and an mpu 6050 accelerametor. I managed to get the acceleratmetor to work and have 1 value come out of movements. So when a peak it hit (aka, the threshold of 1.00 is hit) n gets incremetented with 1. So it work a bit like a pedometer. This value is pushed to my firebase DB.
However mY problem is that after pushing it once, so the value of n is 1. The program blocks for a second and either slows down bad or the accelerametor value drops to 0. this only happens when i my piece of firebase code in. Im not sure if this causes any delays..
here is my part of my code:
#include <Wire.h>
#include "ESP8266WiFi.h"
#include "FirebaseArduino.h"
#define FIREBASE_HOST "XXXXXXXXXX.firebaseio.com" //Without http:// or https:// schemes
#define FIREBASE_AUTH "XXXXX"
#define WIFI_SSID "Bankai"
#define WIFI_PASSWORD "nvvxiegj"
const float HI_THRESHOLD = 1.00;
const float LO_THRESHOLD = 0.70;
bool count_flag = false;
int n= 0; //will be used to store the count
int oldValue = n;
String myString;
const uint8_t MPU_addr = 0x68; // I2C address of the MPU-6050
const float MPU_GYRO_250_SCALE = 131.0;
const float MPU_GYRO_500_SCALE = 65.5;
const float MPU_GYRO_1000_SCALE = 32.8;
const float MPU_GYRO_2000_SCALE = 16.4;
const float MPU_ACCL_2_SCALE = 16384.0;
const float MPU_ACCL_4_SCALE = 8192.0;
const float MPU_ACCL_8_SCALE = 4096.0;
const float MPU_ACCL_16_SCALE = 2048.0;
struct rawdata {
  int16_t AcX; //Acceleration
  int16_t AcY; //Acceleration
  int16_t AcZ; //Acceleration
  int16_t Tmp;
  int16_t GyX; //Gyroscope
  int16_t GyY; //Gyroscope
  int16_t GyZ; //Gyroscope
// Using int variables to convert later on to degrees and decimals
struct scaleddata {
  float AcX; //Acceleration
  float AcY; //Acceleration
  float AcZ; //Acceleration
  float Tmp;
  float GyX; //Gyroscope
  float GyY; //Gyroscope
  float GyZ; //Gyroscope
bool checkI2c(byte addr);
void mpu6050Begin(byte addr);
rawdata mpu6050Read(byte addr, bool Debug);
void setMPU6050scales(byte addr, uint8_t Gyro, uint8_t Accl);
void getMPU6050scales(byte addr, uint8_t &Gyro, uint8_t &Accl);
scaleddata convertRawToScaled(byte addr, rawdata data_in, bool Debug);
//start connection, serial, and connection to db
  Wire.begin();
  mpu6050Begin(MPU_addr);
    WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
  Serial.print("Connecting to Wi-Fi");
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
    delay(100);
  Serial.print("Connected with IP: ");
    Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
//if the value now is different from the current value it gets pushed to the DB, otherwise a flood of numbers apperars.
  rawdata next_sample;
  setMPU6050scales(MPU_addr, 0b00000000, 0b00010000);
  next_sample = mpu6050Read(MPU_addr, false);
  convertRawToScaled(MPU_addr, next_sample, false);
This is the part I think causes the issues:
  //myString = String(n);
  if(oldValue != n){
   Firebase.setInt("Reps/Value", n);
  delay(100); // Wait 5 seconds and scan again
void mpu6050Begin(byte addr) {
  // This function initializes the MPU-6050 IMU Sensor
  // It verifys the address is correct and wakes up the
  // MPU.
  if (checkI2c(addr)) {
    Wire.beginTransmission(MPU_addr);
    Wire.write(0x6B); // PWR_MGMT_1 register
    Wire.write(0); // set to zero (wakes up the MPU-6050)
    Wire.endTransmission(true);
    delay(30); // Ensure gyro has enough time to power up
bool checkI2c(byte addr) {
  // We are using the return value of
  // the Write.endTransmisstion to see if
  // a device did acknowledge to the address.
  Serial.println(" ");
  Wire.beginTransmission(addr);
  if (Wire.endTransmission() == 0)
    Serial.print(" Device Found at 0x");
    Serial.println(addr, HEX);
    return true;
    Serial.print(" No Device Found at 0x");
    return false;
rawdata mpu6050Read(byte addr, bool Debug) {
  // This function reads the raw 16-bit data values from
  // the MPU-6050
  rawdata values;
  Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
  Wire.endTransmission(false);
  Wire.requestFrom(addr, 14, true); // request a total of 14 registers
  values.AcX = Wire.read() << 8 | Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
  values.AcY = Wire.read() << 8 | Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
  values.AcZ = Wire.read() << 8 | Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
  return values;
void setMPU6050scales(byte addr, uint8_t Gyro, uint8_t Accl) {
  Wire.write(0x1B); // write to register starting at 0x1B
  Wire.write(Gyro); // Self Tests Off and set Gyro FS to 250
  Wire.write(Accl); // Self Tests Off and set Accl FS to 8g
void getMPU6050scales(byte addr, uint8_t &Gyro, uint8_t &Accl) {
  Wire.write(0x1B); // starting with register 0x3B (ACCEL_XOUT_H)
  Wire.requestFrom(addr, 2, true); // request a total of 14 registers
  Gyro = (Wire.read() & (bit(3) | bit(4))) >> 3;
  Accl = (Wire.read() & (bit(3) | bit(4))) >> 3;
float filteredAx = 0;
float filteredAy = 0;
float filteredAz = 0;
scaleddata convertRawToScaled(byte addr, rawdata data_in, bool Debug) {
  scaleddata values;
  float scale_value = 0.0;
  byte Gyro, Accl;
  getMPU6050scales(MPU_addr, Gyro, Accl);
  values.GyX = (float) data_in.GyX / scale_value;
  values.GyY = (float) data_in.GyY / scale_value;
  values.GyZ = (float) data_in.GyZ / scale_value;
  scale_value = 0.0;
  if (Debug) {
    Serial.print("Accl Full-Scale = ");
  switch (Accl) {
    case 0:
      scale_value = MPU_ACCL_2_SCALE;
      if (Debug) {
        Serial.println("±2 g");
    case 1:
      scale_value = MPU_ACCL_4_SCALE;
      if (Debug) {
        Serial.println("±4 g");
    case 2:
      scale_value = MPU_ACCL_8_SCALE;
      if (Debug) {
        Serial.println("±8 g");
    case 3:
      scale_value = MPU_ACCL_16_SCALE;
      if (Debug) {
        Serial.println("±16 g");
    default:
  float filterConstant = 0.05;
  values.AcX = (float) data_in.AcX / scale_value;
  values.AcY = (float) data_in.AcY / scale_value;
  values.AcZ = (float) data_in.AcZ / scale_value;
  filteredAx = filteredAx * (1.0 - filterConstant) + values.AcX * filterConstant;
  filteredAy = filteredAy * (1.0 - filterConstant) + values.AcY * filterConstant;
  filteredAz = filteredAz * (1.0 - filterConstant) + values.AcZ * filterConstant;
  float result = sqrt((filteredAx * filteredAx) + (filteredAy * filteredAy ) + (filteredAz * filteredAx ));
//  Serial.print(values.AcX); Serial.print("\t");
//  Serial.print(filteredAx); Serial.print("\t");
  Serial.println(result);
  //    Serial.print(values.AcY); Serial.print("\t");
  //    Serial.print(values.AcZ);
//  Serial.println();
 if( result > HI_THRESHOLD && !count_flag) //if analog_in > Hi_THRESHOLD and count_flag == false
           n++;
           count_flag = true;
     if(result <= HI_THRESHOLD) //set count_flag to false only when below the threshold
           count_flag = false;
  Serial.println(n);
  return values;
Can you help me find the problem? Thank you!
Is that your entire code?
Hi Tom,
No it isnt! I just added the full code in.. Thank you for taking the time to look at it.. !
I don't see where you are setting oldValue to n so I don't think you will ever write to firebase more than once.
