acquire analog pressure from water pressure sensor
Hi, I need to acquire an analog input from a water pressure sensor: http://www.ebay.it/itm/DC5V-1-4-inch-Pressure-Sensor-For-Water-Pressure-Measurement-/271651656872
What kind of connection must I achieve to acquire that signal? Do I need a pull-down resistor to GND connected to Arduino analog input?
From the ad:
Input:DC5V
Output:0.5-4.5V
Pressure range :0-1.2 MPa
Connect red to 5V, black to ground, yellow direct to a 5V capable analog input, no pull up or down. Can’t be much easier.
const unsigned long MIN_PRESSURE = 0UL;
const unsigned long MAX_PRESSURE = 1200000UL;  // 1.2 MPa
const int MIN_READING = 0;
const int MAX_READING = 1024 * 4.5 / 5;  // Reading for 4.5V
// Assuming the data output of the sensor is connected to A0:
unsigned long pressure_in_Pascals = map(analogRead(A0), MIN_READING, MAX_READING, MIN_PRESSURE, MAX_PRESSURE);
Thanks!
