Acquire analog pressure from water pressure sensor
Hi, I need to acquire an analog input from a water pressure sensor: (15 PSI pressure sensor)
https://www.amazon.de/dp/B07GLHVK4R/?coliid=I133OBUIVKMZLK&colid=1RV6PNM93XN0E&psc=0&ref_=lv_ov_lig_dp_it
I tried this code but it is giving very low-pressure values in 0.1 PSI, the calculated values are 3-4 psi. Am I making any mistake? need your suggestions and help thanks
I am using this pump in order to measure the inlet pressure.
https://www.amazon.de/dp/B071JXJ9BR/?coliid=I34X0OTJCMC3CK&colid=1RV6PNM93XN0E&psc=0&ref_=lv_ov_lig_dp_it
void setup() { Serial.begin(9600); }
void loop(){ int sensorVal=analogRead(A1); Serial.print("Sensor Value: "); Serial.print(sensorVal);
float voltage = (sensorVal*5.0)/1024.0; Serial.print("Volts: "); Serial.print(voltage);
delay(100); }
Can’t get your links to work .
What’s the basic specification of your transducer and how have you wired it up ?
You seem to have it connected to a pump - how are you calculating / measuring your pressure from a pump inlet ??
