this is my first time working with an acrylic enclosure. i'm wondering what is a safe thickness to start with? i'm going to be threading jacks and knobs onto this panel. So on one hand it has to be thick enough to feel sturdy when plugging things in and out, and on the other hand it has to be thin enough for looping a small knob or an 1/8" jack through it.
If you have the option of using polycarbonate do so - it is much much easier to drill and cut. As well has being virtually unbreakable.
I think the main factor govering the thickness will be the size of panel and how much flexing you can accept.
If the panel is small or is not subject to heavy loads I reckon 2mm or 3mm would be fine. I have some 2mm acrylic for a dust cover and it is quite robust. I have a small piece of 8mm polycarbonate (left over from sailboat windows) and it feels like it could support an elephant.
...R
I use 1/16 acrylic all the time to make boxes.
If I need more thickness, I use a double or triple thickness, glued together with fast bond.
Always drill acrylic slowly with a step drill (unibit) like this:
thank you this is very helpful!
I use 3/16" mostly because I have lots of leftovers from when I worked in the sign industry. If your wanting to thread into it, I wouldn't go any thinner.
A good trick I learned back then was to only use dull drill bits on acrylic, Sharp ones dig in to fast and crack it.
I have gone so far as running a new bit into concrete to dull it before using it for acrylic. It does work.
