My plan was to get an MKRFOX1200 to Messure currents of my solar system and send them to my own API.
The issue is, I cannot get the ACS712 to work, since the MKRFOX1200 only wants 3.3v on the pins, I can supply the Sensor with 5v but I cannot feed the 5v back to the pins or I will kill my 35EUR board.
I bought a level shifter but I got told that thing is useless and the sensor does not even turn on anymore, only when I supply it with 5v direct and the GND/Output goes throught the level shifter but then I get wired results like -8-10A.
The ACS712 is simply not compatible with 3.3volt processors.
If Aref is not the same as sensor supply, zero current point will drift (Google Ratiometric).
That means level shifters won't help.
How big is this setup.
An INA219 breakout board might do for small (12volt) solar panels.
Leo..
