ACS712 current sensor code problem
Hi guys, I have a question to ask. It is about the coding of the ACS712 current sensor that I found on internet.
Measuring Current Using ACS712
const int analogIn = A0;
int mVperAmp = 185; // use 100 for 20A Module and 66 for 30A Module
int RawValue= 0;
int ACSoffset = 2500;
double Voltage = 0;
double Amps = 0;
void setup(){
void loop(){
 RawValue = analogRead(analogIn);
 Voltage = (RawValue / 1024.0) * 5000; // Gets you mV
 Amps = ((Voltage - ACSoffset) / mVperAmp);
 Serial.print("Raw Value = " ); // shows pre-scaled value
 Serial.print(RawValue);
 Serial.print("\t mV = "); // shows the voltage measured
 Serial.print(Voltage,3); // the '3' after voltage allows you to display 3 digits after decimal point
 Serial.print("\t Amps = "); // shows the voltage measured
 Serial.println(Amps,3); // the '3' after voltage allows you to display 3 digits after decimal point
 delay(2500);
Actually what is ACSoffset and why is 2.5v?
Because it's for measuring AC current and was shifted from - 2.5v + 2.5v to 0 +5v
But if I wanted to measure DC current from a solar panel?
menloon:
So you will be using only halve of diapason.
menloon: But if I wanted to measure DC current from a solar panel?
The 2500 has nothing to do with AC or DC. The ACS712 is a bi-directional current sensor, that outputs half of it's own supply with no current going through the sensor. Meaning you can measure DC charge and discharge currents, or positive/negative going currents with AC. It also means you have only half of the A/D range if you are only going to use it for one-way current. And with the 10-90% span of the sensor, you only have 40% of the A/D to work with (about 410 values). So pick your sensor range wisely (there are three types of ACS712).
Maybe you should also look at an INA219 breakout board. Leo..
Wawa: The 2500 has nothing to do with AC or DC. The ACS712 is a bi-directional current sensor, that outputs half of it's own supply with no current going through the sensor. Meaning you can measure DC charge and discharge currents, or positive/negative going currents with AC. It also means you have only half of the A/D range if you are only going to use it for one-way current. And with the 10-90% span of the sensor, you only have 40% of the A/D to work with (about 410 values). So pick your sensor range wisely (there are three types of ACS712).
Thanks for the advice. I guess I know what to do next =)
