Hello,
I am trying to get the amp-hour from a circuit of LEDs using the ACS712 current sensor, so I need some help in the sketch. There is some variable type that I am doing wrong and getting the "nan" and "inf" values on the monitor.
here is my sketch and attached is the monitor result:
float sample2 = 0.0;
float val = 0.0;
float actualval = 0.0;
float amps = 0.0;
float totamps = 0.0;
float avgamps = 0.0;
float amphr = 0.0;
float watt = 0.0;
float energy = 0.0;
float milisec = millis(); // calculate time in milliseconds
float time=milisec/1000.0; // convert milliseconds to seconds
// taking 150 samples from sensors with a interval of 2msec and then average the samples data collected
for(int i=0;i<150;i++)
sample2+=analogRead(A0); //read the current from sensor
delay(2);
sample2=sample2/150;
val =(5.0*sample2)/1024.0;
actualval =val-2.5; // offset voltage is 2.5v
amps =actualval*10; // 100mv/A from data sheet, 10 is a factor
Serial.print("milisec: ");
Serial.println(milisec);
Serial.print("time: ");
Serial.println(time);
Serial.print("analog: ");
Serial.println(analogRead(A0));
Serial.print("Ampere: ");
Serial.println(amps);
totamps=totamps+amps; // calculate total amps
avgamps=totamps/time; // average amps
amphr=(avgamps*time)/3600.0; // amp-hour
//watt =voltage*amps; // power=voltage*current
energy=(watt*time)/3600; // Watt-sec is again convert to Watt-Hr by dividing 1hr(3600sec)
// energy=(watt*time)/(1000*3600); for reading in kWh
Serial.print("Avg Amps: ");
Serial.println(avgamps);
Serial.print("Total Amps: ");
Serial.println(totamps);
Serial.print("AmpH: ");
Serial.println(amphr);
your getting NAN and INF because you are not updating 'time' and 'millisec' in your loop.
I've added those lines to your code (compiles, not tested!):
float val = 0.0;
float amps = 0.0;
float amphr = 0.0;
float watt = 0.0;
float energy = 0.0;
float time = milisec / 1000.0; // convert milliseconds to seconds
for (int i = 0; i < 150; i++)
sample2 += analogRead(A0); //read the current from sensor
delay(2);
sample2 = sample2 / 150;
val = (5.0 * sample2) / 1024.0;
actualval = val - 2.5; // offset voltage is 2.5v
amps = actualval * 10; // 100mv/A from data sheet, 10 is a factor
time = (millis() - milisec) / 1000.0;
milisec = millis();
Serial.print("Averaging time: ");
totamps = totamps + amps; // calculate total amps
avgamps = totamps / time; // average amps
amphr = (avgamps * time) / 3600.0; // amp-hour
energy = (watt * time) / 3600; // Watt-sec is again convert to Watt-Hr by dividing 1hr(3600sec)
hope that helps....
sherzaad:
float val = 0.0;
float amps = 0.0;
float amphr = 0.0;
float watt = 0.0;
float energy = 0.0;
delay(2);
milisec = millis();
//watt =voltageamps; // power=voltagecurrent
// energy=(watttime)/(10003600); for reading in kWh
hope that helps....
oops ! I did not notice that when i made up the sketch. Thanks a lot I am testing now I must leave the circuit running for a while to see if amph will update from 0.00
