ACS712, surveillance de courant de charge, en utilisant deux relais de 5v et un potentiomètre
Principe de fonctionnement
le deux relais est activé si et seulement si la valeur du courant mesuré ne dépasse pas la valeur choisit par le potentiomètre
dans le cas contraire un seul relais est activé
// include the library code:
#include <LiquidCrystal.h> //library for LCD
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(13, 12, 11, 10, 9, 8);
#define relay 7
#define Relay 6
//Measuring Current Using ACS712
const int Sensor_Pi = A0; //Connect current sensor with A0 of Arduino
int sensitivit = 100; // use 100 for 20A Module and 66 for 30A Module
int offsetvoltag = 2532;
float POT;
float I_Max;
{ Serial.begin(9600);
  lcd.begin(20, 4); // set up the LCD's number of columns and rows:
  pinMode(relay,OUTPUT);
  pinMode(Relay,OUTPUT);
  pinMode(POT,INPUT);
{ POT = analogRead(A1);
  I_Max = map(POT,0,1023,0,20);
  //digitalWrite(relay,HIGH);
 unsigned int tem=0;
 float maxpoin = 0;
 for(int T=0;T<500;T++)
  if(tem = analogRead(Sensor_Pi), tem>maxpoin)
    maxpoin = tem;
 float ADCvalu = maxpoin;
 double Voltag = (ADCvalu / 1024.0) * 5000; // Gets you mV
 double Curren = ((Voltag - offsetvoltag) / sensitivit);
 double AC_Curren = ( Curren ) / ( sqrt(2) );
  lcd.setCursor(0,0);
  lcd.print("I_Max : ");
  lcd.print(I_Max);
  lcd.print(" A ");
 // lcd.setCursor(0,1);
 // lcd.print(" ");
 lcd.setCursor(0,2);
 lcd.print(" AC Current = ");
 lcd.print(AC_Curren,2);
  lcd.print("A  "); //unit for the current to be measured
 delay(100); //delay in milli-sec
switch ((AC_Curren)<I_Max) {
case 1: digitalWrite(relay,HIGH);
   digitalWrite(Relay, HIGH);
case 2:digitalWrite(relay,HIGH);
          digitalWrite(Relay, LOW);
   break;}
Topic moved to French forum.
@patrick521f please read the forum guide before posting again. Clearly you are attempting to be helpful but also you are not familiar with forum rules.
En principe, c'est plus "agréable" pour le lecteur si le demandeur décrit son probléme ou pose une question...
Bonjour et bienvenue,
Merci de prendre quelques minutes pour lire "Les bonnes pratiques du forum francophone" et les appliquer.
