totally new here , im wanting to control a dc motor in a handbrake so im looking to turn on to a given load and then a timed off
the motor unit pull 170 newtons at around 1.2 amps , acs712 is proposed for the load sensing and a nano to operate relays
plan is to use the relays to give pole reversal for the off section and power
cheers
Do you have the acs712 in your hand or do you have the break out board in your hand? Looks like they are both discontinued and no stock is available.
Except for the current sensing, all of your project is doable for testing without using an Arduino.
cheers
Please try again and give us the information we need. Links to all the hardware, and clear
explanation of what you are trying to do using more than one sentence if possible.
If you are new, go and read the instructions for posting in the various sticky threads, it will
improve the chances we can meaningfully help.
