Hello,
I'm pretty new here and this is my first post.
I'm using a Arduino Uno to make a switch to sync two equipment. One equipment has analog output with the range from 0-5V. I let this signal go to AIN0 (I/O6) and also set AIN1 (I/O7) as 0.2V, so when the signal on AIN0 goes up to 0.2V, the internal ACSR trigger an interrupt to let I/O5 light on a LED for a bit and shut it down.
The ACSR is set based on the Amega328 datasheet and the interrupt triggering is on comparator output rising edge.
However, I found a problem that whenever the signal on AIN0 is changing higher or lower than 0.2V, an interrupt is triggered, even if I already set the triggering on the "AOC rising edge".
Could you please tell me what's the problem here? I attach my code underneath.
Thanks a lot!!!
volatile bool triggered= false;
int Rled=5;
pinMode (Rled, OUTPUT);
digitalWrite (Rled, LOW);
ADCSRB =0;
// set ACSR
ADCSRB =0;
bitSet(ACSR,ACI);
bitSet(ACSR,ACIE);
bitSet(ACSR,ACIS1);
bitSet(ACSR, ACIS0);
bitClear(ACSR, ACIC);
bitClear(ACSR, ACBG);
if(triggered)
digitalWrite(Rled, HIGH);
delay(2000);
digitalWrite(Rled, LOW);
triggered=false;
ISR (ANALOG_COMP_vect)
triggered = true;
sketch_apr24a.ino (829 Bytes)
