ACST1635 logic controlled AC Switch help
Hello community,
Wishing you the happy and covid-free 2021.
I've been trying to build a small home automation project using ESP32, PubSub client and an MQTT broker on Android. Rest all is fine, but I was trying NOT to use a relay for controlling the appliances. While considering Solid State Relays, I came across ACST1635 from ST Microelectronics. Looks to be a great component since it can handle upto 16A AC load and can be directly controlled using a uC. All that in a small TO220 package.
My trouble is that, I'm unable to understand the design correctly from the datasheet (please excuse my hobbyist electronics skills). Of what I could see, the "COM" terminal is common to the DC GND of the uC board, and also to the Line Neutral. But I'm not 100% sure if that is how the setup is. And if that is the setup, wouldn't it be risky to have the Line neutral connected directly to the uC board GND? Is there a better way to isolate both DC GND and Line Neutral? I wonder if there is some sort of short circuit or leakage on the AC side, it might enter the uC board and blow it up.
Would someone be able to help me with better understanding how the design is, whether my schematic is correct, and what best to do to ensure safety?
I see that there is another option of SSR-25A as well which is electronically isolated, but that appeared to be a bulky one, which I was trying to avoid.
From your description of your skills do not build it. You have the mains connected to the logic via the logic ground and AC neutral. By the current NEC code the neutral is an independent circuit from the ground. They are connected at only one point, the main disconnect along with the earth ground. If the AC neutral lifts for any reason you may be surrounded by an acrid smell and smoke. The SSR-25A will fit in a standard electrical box with a receptacle but you will have to add a separator to be safe. They also make smaller versions of this rated at a lower amperage. Yes it can be done but only by somebody being supervised by an experienced and or licenced person. We want to keep you around for more projects.
