I have two sketches open, One does not show the action options
e.g. Verify, Upload, Debug. I have a board & port selected
Left shows what I would expect, right the editor with missing items.
If I close the instance with Items the second windows is still missing these.
May be a bug, I downloaded 2.0.0 last night and was having the exact same issues was also having issues were library's would show in one sketch but not the other.
Hi @Xinonix. Does the problem occur reproducibly? For example: if you restart the Arduino IDE and then open those two sketches again, is the toolbar still missing in one of the two IDE windows?
I haven't been able to reproduce the issue, so if either of you can provide instructions I can follow to produce it then it would be helpful.
i managed to recreate library fault every time i am not sure what it is, could possibly be a down to an old pc, but when i rolled back to the old update the issue gone and library seems normal.
Hi @aquos_technical_services. I would be interested in investigating the library fault if you can provide a detailed description of the problem and instructions I can follow to reproduce it.
