Activate a neopixel library with a button
So i got the button working in the serial. But now i have a neopixel library for a ledstrip that i would like to trigger with the click of a button, but i have no clue how i would go about this.
Here's the 2 separate codes
int ledPin = D5; // choose the pin for the LED
int inPin = D7;   // choose the input pin (for a pushbutton)
int val = 0;     // variable for reading the pin status
  pinMode(ledPin, OUTPUT);  // declare LED as output
  pinMode(inPin, INPUT);    // declare pushbutton as input
void loop(){
  val = digitalRead(inPin);  // read input value
  if (val == HIGH) {         // check if the input is HIGH (button released)
    Serial.println("HOOOOOG");
    digitalWrite(ledPin, LOW);  // turn LED OFF
    digitalWrite(ledPin, HIGH);  // turn LED ON
        Serial.println("laag");
// NeoPixel Ring simple sketch (c) 2013 Shae Erisson
// released under the GPLv3 license to match the rest of the AdaFruit NeoPixel library
#ifdef __AVR__
  #include <avr/power.h>
#endif
// Which pin on the Arduino is connected to the NeoPixels?
// On a Trinket or Gemma we suggest changing this to 1
#define PIN            D5
// How many NeoPixels are attached to the Arduino?
#define NUMPIXELS      12
// When we setup the NeoPixel library, we tell it how many pixels, and which pin to use to send signals.
// Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest
// example for more information on possible values.
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
int delayval = 500; // delay for half a second
  // This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket
//#if defined (__AVR_ATtiny85__)
//  if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
//#endif
  // End of trinket special code
  pixels.begin(); // This initializes the NeoPixel library.
  // For a set of NeoPixels the first NeoPixel is 0, second is 1, all the way up to the count of pixels minus one.
  for(int i=0;i<NUMPIXELS;i++){
    // pixels.Color takes RGB values, from 255,0,0 up to 0,255,255
    pixels.setPixelColor(i, pixels.Color(150,0,0)); // Moderately bright green color.
    pixels.show(); // This sends the updated pixel color to the hardware.
    delay(delayval); // Delay for a period of time (in milliseconds).
Put the NeoPixel for loop in a function and call it when the button becomes pressed.
Thanks for the reply. I've been trying to get it working but no success yet :frowning:
Im not quite sure how to call it with the button as well.
Here's the code i've been trying with
#ifdef __AVR__
#endif
#define PIN            D5
int delayval = 700; // delay for half a second
void loop(){
  } /*else {
function pixels(){
That doesn't compile. Here's a version that does. I don't have the hardware to test it (yet).
#ifdef __AVR__
#endif
const byte ledPin=5;
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, ledPin, NEO_GRB + NEO_KHZ800);
int inPin = 7;   // choose the input pin (for a pushbutton)
  if (val == HIGH)
    SetPixels();
  } /*else {
void SetPixels()
  for (int i = 0; i < NUMPIXELS; i++)
    pixels.setPixelColor(i, pixels.Color(150, 0, 0)); // Moderately bright green color.
Dude, you're a legend. the button works. I have an arduino with D5 and D7 and such only had to change that. Many thanks!
NO NEED DECLARE LEDPIN AS OUTPUT AGAIN
