Activate a relay only once every time you press a button for bluetooth
Hello, I am new with Arduino, I am trying to activate a relay through a bluetooth controlled app, but every time I press the button on the mobile phone, the relay turns on and off continuously.
This is the code I use:
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
bool doneFlag = false;
SoftwareSerial mySoftwareSerial(10, 11); // RX, TX
  /*BLUETOOH*/
SoftwareSerial BT(12,13); // RX, TX
char command;
String string;
  /*BLUETOOH*/
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
# define ACTIVATED LOW
/*RELEVADOR*/
int pinOut = 2;
/*RELEVADOR*/
/*SE ESTABLECE E PIN PARA REALIZAR CADA ACCION, EJEMPLO, BIENVENIDA CON EL PIN 9 DE ARDUINO*/
int btnpuerta = 7;
int btnwelcome = 6;
int btnreload = 8;
  /*SETUP PARA CADA ACCION EN ARDUINO*/
  pinMode(btnpuerta, INPUT);
  digitalWrite(btnpuerta,HIGH);
  pinMode(btnwelcome, INPUT);
  digitalWrite(btnwelcome,HIGH);
  pinMode(btnreload, INPUT);
  digitalWrite(btnreload,HIGH);
  /*RELEVADOR*/
  pinMode (pinOut, OUTPUT);
  /*RELEVADOR*/
  /*BLUETOOH*/
  BT.begin(9600);
  /*BLUETOOH*/
  mySoftwareSerial.begin(9600);
  /*BLUETOOH*/
  mySoftwareSerial.listen();
  /*BLUETOOH*/
  Serial.println(F("Escanmotor.com"));
  Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)"));
  if (!myDFPlayer.begin(mySoftwareSerial)) {  //Use softwareSerial to communicate with mp3.
    Serial.println(F("Unable to begin:"));
    Serial.println(F("1.Please recheck the connection!"));
    Serial.println(F("2.Please insert the SD card!"));
    while(true);
  Serial.println(F("DFPlayer Mini online."));
  myDFPlayer.setTimeOut(500); //Set serial communictaion time out 500ms
  //----Set volume----
  myDFPlayer.volume(30);  //Set volume value (0~30).
  myDFPlayer.volumeUp(); //Volume Up
  myDFPlayer.volumeDown(); //Volume Down
  //----Set different EQ----
  myDFPlayer.EQ(DFPLAYER_EQ_NORMAL);
  //----Set device we use SD as default----
  myDFPlayer.outputDevice(DFPLAYER_DEVICE_SD);
  //----Read imformation----
  Serial.println(myDFPlayer.readState()); //read mp3 state
  Serial.println(myDFPlayer.readVolume()); //read current volume
  Serial.println(myDFPlayer.readEQ()); //read EQ setting
  Serial.println(myDFPlayer.readFileCounts()); //read all file counts in SD card
  Serial.println(myDFPlayer.readCurrentFileNumber()); //read current play file number
  Serial.println(myDFPlayer.readFileCountsInFolder(3)); //read file counts in folder SD:/03
void loop(){
  /*BLUETOOH*/
  BT.listen();
  delay(50);
  if (BT.available() > 0)
    string = "";
  // Serial.println(string);
  while (BT.available() > 0) {
    command = ((byte) BT.read());
    Serial.println(command);
    if (command == ':')
    else {
      string += command;
    delay(10);
  switch (command) {
    case 'P':
      reproducir();     // Reproduccion
  /*BLUETOOH*/
  if (digitalRead(btnpuerta) == ACTIVATED) {
    myDFPlayer.play(1);
    delay(2500);
  if (digitalRead(btnwelcome) == ACTIVATED) {
       if (doneFlag == false) // fragmento para repetir el comando una sola vez
          myDFPlayer.play (5);
          delay (2000);
          myDFPlayer.stop ();
          doneFlag = true;
  if (digitalRead(btnreload) == ACTIVATED) {
    doneFlag == true;
void reproducir() {    // Reproduccion
    //Le mandamos la señal de HIGH a la salida del
    //Arduino, la salida es el pin 2
    digitalWrite (pinOut, HIGH);
    //Hacemos un delay de 1 segundo
    delay (1000);
    digitalWrite (pinOut, LOW);
void printDetail(uint8_t type, int value){
  switch (type) {
    case TimeOut:
      Serial.println(F("Time Out!"));
    case WrongStack:
      Serial.println(F("Stack Wrong!"));
    case DFPlayerCardInserted:
      Serial.println(F("Card Inserted!"));
    case DFPlayerCardRemoved:
      Serial.println(F("Card Removed!"));
    case DFPlayerCardOnline:
      Serial.println(F("Card Online!"));
    case DFPlayerUSBInserted:
      Serial.println("USB Inserted!");
    case DFPlayerUSBRemoved:
      Serial.println("USB Removed!");
    case DFPlayerPlayFinished:
      Serial.print(F("Number:"));
      Serial.print(value);
      Serial.println(F(" Play Finished!"));
    case DFPlayerError:
      Serial.print(F("DFPlayerError:"));
      switch (value) {
        case Busy:
          Serial.println(F("Card not found"));
        case Sleeping:
          Serial.println(F("Sleeping"));
        case SerialWrongStack:
          Serial.println(F("Get Wrong Stack"));
        case CheckSumNotMatch:
          Serial.println(F("Check Sum Not Match"));
        case FileIndexOut:
          Serial.println(F("File Index Out of Bound"));
        case FileMismatch:
          Serial.println(F("Cannot Find File"));
        case Advertise:
          Serial.println(F("In Advertise"));
        default:
    default:
100 / 5,000
Translation results
How can I make it only activate once, every time I press the button on the mobile phone?
very thnks, im a noob
How is the relay connected and which pin is it connected to?
it is connected to pin 2 which goes to one end of the coil, and the other end to GND
Does Serial.print() print a "P" continuously or just once or not at all? Do you ever send a different command to stop the relay?
From android studio I send the following command:
btPlay.setOnClickListener(new View.OnClickListener() {
            @Override
            public void onClick(View v) {
                reproducir();
and the reproduction is done from arduino, the idea was that from Arduino it would stop in 1 second, automatically
Hello saagcs
Post a picture and schematic to see how we can help.
duplicate thread here >>> https://forum.arduino.cc/t/activate-a-relay-only-once-each-time-a-button-is-pressed/967996
@saagcs, do not cross-post. Other thread removed.
