Activating a sequence of events when a digit display = 3
Hi all I have a project that I was doing where when the 7 segment digit display shows a 3, a buzzer and stepper motor activate and do their thing. I have most to all of the code written but I cannot seem to get the motor and buzzer to activate when I need to. Thank you in advance for help.
#include "pitches.h"
const int a = 8;  //For displaying segment "a"
const int b = 9;  //For displaying segment "b"
const int c = 4;  //For displaying segment "c"
const int d = 5;  //For displaying segment "d"
const int g = 3;  //For displaying segment "g"
bool bPress = false;
const int buttonPin = 10;
// Variables will change:
int buttonPushCounter = 1;   // counter for the number of button presses
int buttonState = 1;         // current state of the button
int lastButtonState = 0;
#define echoPin 12
#define trigPin 11
long duration;
int distance;
#define IN1 6
#define IN2 2
#define IN3 1
#define IN4 0
int Steps = 0;
boolean Direction = true;// gre
unsigned long last_time;
unsigned long currentMillis ;
int steps_left=4095;
long time;
int melody[]= {NOTE_E5, NOTE_G5, NOTE_E6, NOTE_C6, NOTE_D6, NOTE_G6
int noteDurations []={ 8, 8, 8, 8, 8, 8
 pinMode(trigPin, OUTPUT); // Sets the trigPin as an OUTPUT
  pinMode(echoPin, INPUT); // Sets the echoPin as an INPUT
  Serial.begin(9600); // // Serial Communication is starting with 9600 of baudrate speed
  Serial.println("Ultrasonic Sensor HC-SR04 Test"); // print some text in Serial Monitor
  Serial.println("with Arduino UNO R3");
pinMode(IN1, OUTPUT);
pinMode(IN2, OUTPUT);
pinMode(IN3, OUTPUT);
pinMode(IN4, OUTPUT);
// delay(1000);
 pinMode(a, OUTPUT);  //A
  pinMode(b, OUTPUT);  //B
  pinMode(c, OUTPUT);  //C
  pinMode(d, OUTPUT);  //D
  pinMode(g, OUTPUT);  //G
  pinMode( buttonPin , INPUT_PULLUP );
  displayDigit(buttonPushCounter);
void displayDigit(int digit)
 //Conditions for displaying segment a
 if(digit!=1 && digit != 4)
 digitalWrite(a,HIGH);
 //Conditions for displaying segment b
 if(digit != 5 && digit != 6)
 digitalWrite(b,HIGH);
 //Conditions for displaying segment c
 if(digit !=2)
 digitalWrite(c,HIGH);
 //Conditions for displaying segment d
 if(digit != 1 && digit !=4 && digit !=7)
 digitalWrite(d,HIGH);
//Conditions for displaying segment g
 if (digit!=0 && digit!=1 && digit !=7)
 digitalWrite(g,HIGH);
void stepper(int xw){
for (int x=0;x<xw;x++){
switch(Steps){
case 0:
digitalWrite(IN1, LOW);
digitalWrite(IN2, LOW);
digitalWrite(IN3, LOW);
digitalWrite(IN4, HIGH);
case 1:
digitalWrite(IN3, HIGH);
case 2:
digitalWrite(IN4, LOW);
case 3:
digitalWrite(IN2, HIGH);
case 4:
case 5:
digitalWrite(IN1, HIGH);
case 6:
case 7:
default:
SetDirection();
void SetDirection(){
if(Direction==1){
Steps++;
if(Direction==0){
Steps--;
if(Steps>7){
Steps=0;
if(Steps<0){
Steps=7;
void turnOff()
  digitalWrite(a,LOW);
  digitalWrite(b,LOW);
  digitalWrite(c,LOW);
  digitalWrite(d,LOW);
  digitalWrite(g,LOW);
buttonState = digitalRead(buttonPin);
   // step one revolution  in one direction:
// Clears the trigPin condition
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  // Sets the trigPin HIGH (ACTIVE) for 10 microseconds
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  // Reads the echoPin, returns the sound wave travel time in microseconds
  duration = pulseIn(echoPin, HIGH);
  // Calculating the distance
  distance = duration * 0.034 / 2; // Speed of sound wave divided by 2 (go and back)
  // Displays the distance on the Serial Monitor
  Serial.print("Distance: ");
  Serial.print(distance);
  Serial.println(" cm");
 if (buttonState != lastButtonState) {
    // if the state has changed, increment the counter
    if (buttonState == LOW) {
      // if the current state is HIGH then the button went from off to on:
      bPress = true;
      buttonPushCounter++;
      if( buttonPushCounter > 4) buttonPushCounter =0 ;
      Serial.println("on");
      // if the current state is LOW then the button went from on to off:
      Serial.println("off");
    // Delay a little bit to avoid bouncing
    delay(50);
  // save the current state as the last state, for next time through the loop
  lastButtonState = buttonState;
  if( bPress ){
     turnOff();
  if (buttonPushCounter == 3); {
    if(buttonPushCounter == 3);
    for (int thisNote = 0; thisNote < 6; thisNote++) {
    int noteDuration = 1000 / noteDurations[thisNote];
    tone(13, melody[thisNote], noteDuration);
    int pauseBetweenNotes = noteDuration * 1.30;
    delay(pauseBetweenNotes);
    noTone(13); }
    while(steps_left>0){
    currentMillis = micros();
    if(currentMillis-last_time>=1000){
    stepper(1);
    time=time+micros()-last_time;
    last_time=micros();
    steps_left--;
The semicolon is the only code that is dependent on the value of buttonPushCounter. Delete it, and why are you testing the value twice ?
I accidentally put it in there twice. The buzzer works on three now but the stepper motor doesn't move
If you have updated code, please post it in a new message.
Why the strange formatting?
New Code
#define echoPin 12
#define trigPin 11
long duration;
int distance;
#define IN1 6
#define IN2 2
#define IN3 1
#define IN4 0
int Steps = 0;
long time;
// delay(1000);
 if(digit !=2)
      bPress = true;
    delay(50);
  if( bPress ){
     turnOff();
    stepper(1);
    last_time=micros();
    steps_left--;
    Serial.println(time);
    Serial.println("Wait...!");
    delay(2000);
    Direction=!Direction;
    steps_left=4095;
    noTone(13); }
switch(Steps){
case 0:
case 1:
case 2:
case 3:
case 4:
case 5:
case 6:
case 7:
default:
SetDirection();
if(Direction==1){
Steps++;
if(Direction==0){
Steps--;
if(Steps>7){
Steps=0;
if(Steps<0){
Steps=7;
void turnOff()
Properly formatted using ctrl-T:
#define echoPin 12
#define trigPin 11
long duration;
int distance;
#define IN1 6
#define IN2 2
#define IN3 1
#define IN4 0
int Steps = 0;
int steps_left = 4095;
long time;
int melody[] = {NOTE_E5, NOTE_G5, NOTE_E6, NOTE_C6, NOTE_D6, NOTE_G6 };
int noteDurations [] = { 8, 8, 8, 8, 8, 8 };
  // delay(1000);
  if (digit != 1 && digit != 4)
    digitalWrite(a, HIGH);
  if (digit != 5 && digit != 6)
    digitalWrite(b, HIGH);
  if (digit != 2)
    digitalWrite(c, HIGH);
  if (digit != 1 && digit != 4 && digit != 7)
    digitalWrite(d, HIGH);
  if (digit != 0 && digit != 1 && digit != 7)
    digitalWrite(g, HIGH);
      bPress = true;
      if ( buttonPushCounter > 4) buttonPushCounter = 0 ;
    delay(50);
  if ( bPress ) {
    turnOff();
    while (steps_left > 0) {
      if (currentMillis - last_time >= 1000) {
        stepper(1);
        time = time + micros() - last_time;
        last_time = micros();
        steps_left--;
    delay(2000);
    Direction = !Direction;
    steps_left = 4095;
      noTone(13);
void stepper(int xw) {
  for (int x = 0; x < xw; x++) {
    switch (Steps) {
      case 0:
      case 1:
      case 2:
      case 3:
      case 4:
      case 5:
      case 6:
      case 7:
      default:
    SetDirection();
void SetDirection() {
  if (Direction == 1) {
    Steps++;
  if (Direction == 0) {
    Steps--;
  if (Steps > 7) {
    Steps = 0;
  if (Steps < 0) {
    Steps = 7;
void turnOff()
  digitalWrite(a, LOW);
  digitalWrite(b, LOW);
  digitalWrite(c, LOW);
  digitalWrite(d, LOW);
  digitalWrite(g, LOW);
Have you tested the hardware independently, one sketch for each device before testing this sketch?
Yeah, all the components work separately. The stepper motor vibrates but doesn't turn when it is added into the if statement in the code while when I test it independently it works fine.
Is there enough power to move all of the components? How are you supplying power?
Supplying the power through my laptop
Using a volt meter how much voltage does the stepper motor get? Is it enough? Make sure that you have all your other components connected while doing theses tests.
For the stepper ?
What stepper motor is it ?
Thanks.. Tom... :smiley: :+1: :coffee: :australia:
I think your code is vibrating the stepper because it only runs 1 sequence step when you call the function with a value of 1.
        stepper(1);
    switch (Steps) {
      case 0:
I'm willing to bet, the stepper code that you ran successfully, was not this one. It would have been a good idea to have been comparing the two.
