My project is using an arduino board, an ultrasonic range finder (1-HCSR04) and an LED light strip (red indoor 1 meter 55-7060R-0).
I would like to have the lights activate at a slow heart beat at say 10m/30 feet; faster heart beat at say 6m/18 feet and really fast at say 2m/6 feet. I can get the range finder to read to the computer but can't write the arduino program with 'if' statements or && commands to trigger the lights at different speeds. I have the lights working.
I am an artist not an electronic guy and could use some collaboration with this part of the project. Help!!
So... Everything is wired-up? You can read distances and blink the LEDs? You just can't get the blink speed right?
Have you got any code to show us?
Try getting it to work with just 2 speeds first.
If you're not doing this already, use greater-than or less-than to when you're checking distances. Trying to match an exact distance can often cause problems.
Ideally, this is probably a good application for the [u]map()[/u] function. But, if you don't completely understand that function, start with if-statements first.
If you use the map() function, you'll probably want to "constrain" the results so you don't get unreasonable blink times. For example -
if (Distance > 30)
Distance = 30;
Or, you can do something else if the distance is invalid or out or range.
Thanks I will give map a try. The basic program I can get to work is:
Arduino with PIR motion sensor
// For complete project details, visit: Arduino with PIR Motion Sensor | Random Nerd Tutorials
// Modified by Rui Santos based on PIR sensor by Limor Fried
/* HC-SR04 Sensor
https://www.dealextreme.com/p/hc-sr04-ultrasonic-sensor-distance-measuring-module-133696
This sketch reads a HC-SR04 ultrasonic rangefinder and returns the
distance to the closest object in range. To do this, it sends a pulse
to the sensor to initiate a reading, then listens for a pulse
to return. The length of the returning pulse is proportional to
the distance of the object from the sensor.
The circuit:
- VCC connection of the sensor attached to +5V
- GND connection of the sensor attached to ground
- TRIG connection of the sensor attached to digital pin 2
- ECHO connection of the sensor attached to digital pin 4
Original code for Ping))) example was created by David A. Mellis
Adapted for HC-SR04 by Tautvidas Sipavicius
This example code is in the public domain.
const int trigPin = 2;
const int echoPin = 4;
// initialize serial communication:
// establish variables for duration of the ping,
// and the distance result in inches and centimeters:
long duration, inches, cm;
// The sensor is triggered by a HIGH pulse of 10 or more microseconds.
// Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
pinMode(trigPin, OUTPUT);
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Read the signal from the sensor: a HIGH pulse whose
// duration is the time (in microseconds) from the sending
// of the ping to the reception of its echo off of an object.
pinMode(echoPin, INPUT);
duration = pulseIn(echoPin, HIGH);
// convert the time into a distance
inches = microsecondsToInches(duration);
cm = microsecondsToCentimeters(duration);
Serial.print(inches);
Serial.print("in, ");
Serial.print(cm);
Serial.print("cm");
delay(100);
long microsecondsToInches(long microseconds)
// According to Parallax's datasheet for the PING))), there are
// 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
// second). This gives the distance travelled by the ping, outbound
// and return, so we divide by 2 to get the distance of the obstacle.
// See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
return microseconds / 29 / 2;
Here ya go:
// For complete project details, visit: http://RandomNerdTutorials.com/pirsensor
/* HC-SR04 Sensor
The circuit:
* VCC connection of the sensor attached to +5V
* GND connection of the sensor attached to ground
* TRIG connection of the sensor attached to digital pin 2
* ECHO connection of the sensor attached to digital pin 4
class Blinker {
byte pin;
int BPM = 0;
byte lubDub = 0;
unsigned long lubDubMs[4];
unsigned long lubDubStartMs = 0;
public:
Blinker(byte pin) : pin(pin) {}
pinMode(pin, OUTPUT);
if(BPM == 0) return;
if(millis() - lubDubStartMs < lubDubMs[lubDub]) return;
lubDub = (lubDub + 1) % 4;
digitalWrite(pin, (lubDub % 2)==0 ? HIGH : LOW);
lubDubStartMs = millis();
void off() {
BPM = 0;
digitalWrite(pin, LOW);
void setRate(int BPMp) {
if(BPMp == BPM) return; // no change
if(BPMp == 0) { // dead
off();
return;
BPM = BPMp;
if(BPM > 600) { // also dead, but we'll soldier on :)
// this caps our millisecond period to 100ms
BPM = 600;
unsigned long totalMs = 60L * 1000L / BPM;
// I'm not sure how long a 'lub dub' should be. I'll go with 150ms for the 'lub', 100ms for the 'dub',
// and 150ms in between. There should be a pause of (say) 250 after the 'dub'.
// the problem is that this may excced our maximum rate. If it does, we have to compress things :)
// our usual cycle is 600ms, so things start to compress after 100PBM, which seems reasonable
// if the 'compression' > 1, then no compression is needed. We just let the gap after the 'dub'
// take all the slack.
float compress = (float)totalMs / (float)(150 + 150 + 100 + 200);
if(compress > 1) compress = 1;
lubDubMs[0] = 150 * compress;
lubDubMs[1] = 150 * compress;
lubDubMs[2] = 100 * compress;
lubDubMs[3] = totalMs - lubDubMs[0] - lubDubMs[1] - lubDubMs[2];
Blinker led(13); // Blinker on pin 13
unsigned long lastPingMs100;
led.setup();
led.loop();
if(millis()/100 != lastPingMs100) {
ping();
lastPingMs100 = millis() /100;
void ping()
Serial.print(cm);
Serial.print("cm");
// set led rate. You could also compute it using map()
if(inches < 6*12) led.setRate(120);
else if(inches < 30*12) led.setRate(60);
else led.off();
