Activating servo motors and laser module by using motion and sound sensor
Hello everyone,
I am newbie at Arduino so I really need your help.
I found a good project for my cat but i should make it perfect by adding sound and motion sensor. My goal is keep my cat busy when he was crying near the door of my apartment while I was working outside. The project as you can see below works all the time as it’s powered up. I want to keep it powered up all the time but I want it is activated for 5 min. only when my cat is crying or walking around it and stopped after 5 min. and go on like this.
What adjustments should I make?
Thanks in advance.
/* Laser Tower for the CAT - LA FABRIQUE DIY
Pseudo-randomly moves a servo tower (on X and Y axis) and lights up a laser.
x_servo is attached to pin 6 and moves in the X plan
y_servo is attached to pin 9 and moves in the Y plan
Laser is on pin 13 HOW IT WORKS : The program randomly choose a new position for the laser inside a square you can define below.
It checks the new position is different from the old one of at least “minimal_movement”. It moves the tower to the new position and stays still for a time between min_freeze and max_freeze (this aims to reproduce the behaviour of an insect landing somewhere for a bit and then flying off, that’s the variable you need to increase if your cat is fat). Ans starts the process over and over again.
Created 30 Sep 2016 by Lucas Berbesson
#include <Servo.h>
/* YOU CAN CUSTOM THESE VARIABLES IF YOU WANT TO ALTER THE TOWER BEHAVIOUR */
// X servo angle will stay in [min_x, max_x] range
// Y servo angle will stay in [min_y, max_y] range
// to be ajsuted to the size of your living room float
min_x = 5;
float max_x = 50;
float min_y = 5;
float max_y = 35;
int min_freeze = 200;
int max_freeze = 3000;
float minimal_movement = 5;
/* YOU SHOULD NOT HAVE TO MODIFY THE CODE BELOW THIS LINE */
// finding center of square for starting point
int random_delay;
float x_position = min_x + (max_x - min_x)/2;
float y_position = min_y + (max_y - min_y)/2;
float x_old_position = x_position;
float y_old_position = y_position;
float x_new_position;
float y_new_position;
float x_speed;
float y_speed;
int movement_time;
// Instantiating two servos
Servo x_servo;
Servo y_servo;
int pos = 0;
y_servo.attach(6); // attaches the y servo on pin 6 to the servo object
x_servo.attach(9); // attaches the x servo on pin 9 to the servo object
pinMode (13, OUTPUT);
digitalWrite (13, HIGH); // switch on the laser
//Place the servos in the center at the beginning
y_servo.write(y_position);
x_servo.write(x_position);
movement_time = random(10,40);
random_delay = random(min_freeze, max_freeze);
x_new_position = random(min_x+minimal_movement, max_x-minimal_movement);
y_new_position = random(min_y+minimal_movement, max_y-minimal_movement);
if( (y_new_position > y_old_position) && (abs(y_new_position - y_old_position) < 5 )) {
y_new_position = y_new_position + minimal_movement;
} else if ( (y_new_position < y_old_position) && (abs(y_new_position - y_old_position) < 5 )) {
y_new_position = y_new_position - minimal_movement;
if( (x_new_position > x_old_position) && (abs(x_new_position - x_old_position) < 5 )) {
x_new_position = x_new_position + minimal_movement;
} else if ( (x_new_position < x_old_position) && (abs(x_new_position - x_old_position) < 5 )) {
x_new_position = x_new_position - minimal_movement;
x_speed = (x_new_position - x_old_position)/movement_time;
y_speed = (y_new_position - y_old_position)/movement_time;
for (pos = 0; pos < movement_time; pos += 1) {
x_position = x_position + x_speed;
y_position = y_position + y_speed;
delay(10);
x_old_position = x_new_position;
y_old_position = y_new_position;
delay(random_delay);
