I've been googling for a while but I have not found anything about DIY Active RFID.
I understand the general theory; how do active transponders work, differences between passive and active, etc.
I am looking to concrete all that general info into specific components.
What am I building?
- System that tracks objects when cross some specific point, let's call it 'finsih line'
As far as I know,
- Each object will have an active rfid transponder
- The finsih line will have an antenna on the ground.
- Active Rfid Reader will get what is crossing the 'finish line'
What do I need?
- Specific active rfid reader module, if it have a complete datasheet, much better.
- How is the system calibrated to get the exact moment the object cross the 'finish line'?
- The antenna is usually a mat wth the wires behind, any idea about those wires to just put them under the ground with out any mat.
I've seen a few tutorials about passive rfid systems, for running marathon races, but I need a higher accuracy in timing than those.
Thanks ![]()
