Active RFID
i have project to interface active RFID with Arduino.
I already success to read unique code of active RFID tag in Arduino's serial monitor. and the unique code are :
tag 1 : $1C1503110663,01,0010603F, 00
tag 2 : $1C1503110663,01,00106062, 71
tag 3 : $1C1503110663,01,00106054, 74
tag 4 : $1C1503110663,01,00106038, 7E
and want to make if Tag 1 is losing from the Reader area, LED1 will turn ON
if Tag 2 is losing from Reader area, LED2 will turn ON. and continue until tag 4.
but i cant do that !
i already use that code in my program, but still not success.
this is my code :
[#include <SoftwareSerial.h>
#define A_TAG_CODE "$1C1503110663,01,0010603F,00"  //change this ID with your own card TAG
#define B_TAG_CODE "$1C1503110663,01,00106062,71"
#define C_TAG_CODE "$1C1503110663,01,00106054,74"
#define D_TAG_CODE "$1C1503110663,01,00106038,7E"
String msg;
SoftwareSerial RFID(9, 10);
#define ledpin    6
int ledPin = 6;  //Sets pin 13 to LED
 pinMode(ledPin, OUTPUT);  // Sets the digital pin as output
 digitalWrite(ledpin,LOW);
 Serial.begin(38400);
 Serial.println("Serial READY");
 RFID.begin(38400);
 Serial.println("RFID READY");
 char c;
 void loop(){
  msg="";
  while(msg.length()<26){
  while(RFID.available()>0){
    msg += c;
    Serial.write(RFID.read());
    //Serial.println(msg);  //Uncomment to view your tag ID
    //Serial.println(msg.length());
  msg=msg.substring(1,26);
  if(msg.indexOf(A_TAG_CODE)>=0) add1 () ;
  else add () ;
  if(msg.indexOf(B_TAG_CODE)>=0) add1 () ;
  else add () ;
  if(msg.indexOf(C_TAG_CODE)>=0) add1 () ;
  else add () ;
  if(msg.indexOf(D_TAG_CODE)>=0) add1 () ;
  else add () ;
 void add () {
 digitalWrite(ledPin, HIGH);    // sets the LED off
  void add1 () {
  digitalWrite(ledPin, LOW);   // sets the LED on
  delay(2000);                  // waits for a second
Please some body help....please.... :cry:
So, you know exactly how many characters there will be. Yet, you are still pissing away resources using the String class. Why?
Read a character. Write it to the serial port. Don't even think about adding it to msg. Why not?
Through away the first character of the String that you didn't write to. Why?
PaulS:
yes i know, there was 25 character of the Tag's code. so, am i wrong if i make it into string class.. why?
oke i will add it into msg
what did u mean about "Through away first character of the string that i didn't write to"? i didn't through away any character.
Yes you did. Array indexes start at 0, not 1.
