So I'm looking to add a function to my home-brew GPS that gives actual distance covered - i.e. not straightline distance from the start point.
My first go went a bit like this
-create variable called "trip"
-record position (call it "pos1")
-delay for 1 second
-record position (call this one "pos2")
-calculate distance between pos1 and pos2 (call is "dist")
-let trip=trip+dist
-and repeat... (except creating the variable "trip")
However, this doesn't seem to work. I just get zero.
Any ideas on what's going wrong or if there's a more efficient method? (If needs be I can upload my code, but it's a helluva messy at the moment :~ )
-delay for 1 second
-let trip=trip+dist
However, this doesn't seem to work. I just zero.
Matches the amount of code you posted. What a coincidence.
Well I'll try put some of the code here. It runs over multiple tabs in the main program, which makes it easier to see what's going on, but it makes it hard to copy individual bits of code.
long constlon;
long constlat;
unsigned long fix_age;
int trip;
float fltrip;
//The usual setup stuff...
void trip1()
gps.get_position(&constlat, &constlon, &fix_age);
void trip2()
long constlon2;
long constlat2;
unsigned long fix_age2;
gps.get_position(&constlat2, &constlon2, &fix_age2);
float distkm;
distkm=(sqrt(sq(constlat2-constlat)+sq(constlon2-constlon)))/1000; //My TinyGPS version doesn't have distance_to(), so I just use this.
trip=trip+distkm; //this gives an interger trip
fltrip=fltrip+distkm; //this gives a float trip
trip1();
trip2();
Serial.print(trip);
This isn't the exact code, but it represents what I'm trying to achieve (I hope)
Hi Pete.
I figured using the distance formula for a flat plane would be sufficient, since I'm not covering enough distance for the curvature of the earth to make a noticeable difference in results. I might make use of the Haversine formula at a later stage (when I feel like translating it into code XD ).
I don't really know why I'm using "long" values, but TinyGPS suggests I do. Also, using "int" seemed to produce incorrect data.
@Wildbill:
The GPS is meant for my car, so I've been testing it by driving (up to 60km/h... no free-ways yet...). I figured that would produce a measurable difference.
which is why you do have to store the result in a long integer. But your formula isn't going to work because lat and long are angles, not distances, so the Pythagorean theorem isn't going to give a meaningful result.
