Actuate on incoming serial data (NB - IoT)
Hello, I am currently doing a project with NB - IoT. I am using a modem that sends data at 9600 baud to my serial interface. I can control the modem with AT commands. For example, sending AT to the modem returns “OK” over the same interface. I want to respond to that OK by flashing an LED. The ultimate goal is to read incoming data and act on it accordingly. I have done a lot of research and tried everything before I came here but now I’m stuck.
The code works when reading a single character, like “O” or “K” but it doesn’t read a combination like “OK”.
  while (UBLOX.available())
    int len = 6; //buffer length
    char buf[len]; //array buffer
    int index = 0; //array index
    String input = "";
    uint8_t d = UBLOX.read(); //reads incoming serial data
    input = (char)d; //puts serial data into a string as readable ASCII characters
    for(index = 0; index < len; index++) //puts serial data in an array
      buf[index] = char(d);
      if(input = "LF")
    char * pch;
    pch = strstr (buf,"OK");
    USB.print(buf);
    if(pch != 0) //if character wasn't found, pointer returns 0. If it was found, flesh LED.
      flashLED();
The code also has a few problems. It sometimes garbles the serial monitor with weird ascii signs in between the responses to AT commands.
Any help would be appreciated :slight_smile:
This is not complete code but just a small excerpt. Post only complete code, any problem might be in a part of your code you don't imagine.
Also provide as much information about the used hardware as you have.
pylon:
Thank you for your response, I will tomorrow. It's quite a complicated project and this is only a small part of it but I will try to post as much relevant info as possible.
Complete code is posted below. I am using a Arduino M0 with a SODAQ NB-IoT shield on top of it.
I modified an example given by sodaq, which was just a serial passthrough to send and receive AT commands.
#include "Arduino.h"
#if defined(ARDUINO_SODAQ_EXPLORER)
#define USB SerialUSB
#define UBLOX Serial
#elif defined(ARDUINO_SAM_ZERO)
#define UBLOX Serial1
#else
#error "Please use a Sodaq ExpLoRer, Arduino M0 or add your own board."
#endif
// Pin to turn on/off the nb-iot module
#define powerPin 7
unsigned long baud = 9600;  //start at 9600 allow the USB port to change the Baudrate
  // Turn the nb-iot module on
  pinMode(powerPin, OUTPUT);
  digitalWrite(powerPin, HIGH);
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, LOW);
  // Start communication
  USB.begin(baud);
  UBLOX.begin(baud);
void flashLED()
  digitalWrite(LED_BUILTIN, HIGH);
  delay(100);
// Forward every message to the other serial
  while (USB.available())
    uint8_t c = USB.read();
    UBLOX.write(c);
    String input = "";
      if(input = "LF")
    char * pch;
    USB.print(buf);
    if(pch != 0)
      flashLED();
  // check if the USB virtual serial wants a new baud rate
  if (USB.baud() != baud)
    baud = USB.baud();
       UBLOX.begin(baud);
Alright so I investigated a little more. With the code like this the output looks like this:
13
10
79O75K13
10
So it always starts with a carriage return and ends with a linefeed.
I placed a USB.print(d) and a USB.print(input) inside my code for debugging purposes. If you look at the output you can see it first reads the value, outputs an ascii character, reads in a new value and outputs the second ascii character. This means there is never more than one ascii character in my buffer which is exactly what I was trying to avoid. I need to check multiple characters at the same time to see if there is an “OK” in my buffer.
How do I improve my loop so it stores multiple ascii characters in my buffer?
#else
#endif
#define powerPin 7
  USB.begin(baud);
  UBLOX.begin(baud);
void flashLED()
  delay(100);
    UBLOX.write(c);
  String input = "";
    input += (char)d; //puts serial data into a string as readable ASCII characters
    USB.print(d);
//    for(index = 0; index < len; index++) //puts serial data in an array
//      buf[index] = (char)d;
//      USB.print(buf[index]);
//      if(input = "\0")
//        break;
    char * pch;
    if(pch != 0)
      flashLED();
  USB.print(input);
    baud = USB.baud();
       UBLOX.begin(baud);
langestefan:
The 3rd example in Serial Input Basics should be suitable if you change the start and end markers to '\r' and '\n'
...R
Robin2:
...R
Thank you so much!!!
I modified the code and added a strstr function to suit my needs, it works now!
I will be testing with the NB - IoT network soon. In theory I should be able to receive a code on the modem, analyse it and actuate on it now. So if I receive 1234 for instance I turn led 1 on etc.
#if defined(ARDUINO_SAM_ZERO)
#endif
// Pin to turn on/off the nb-iot morcule
#define powerPin 7
  //led setup
  USB.begin(baud);
  UBLOX.begin(baud);
void flashLED()
  delay(100);
const byte numChars = 32;
char receivedChars[numChars];
boolean newData = false;
    UBLOX.write(c);
  recvWithStartEndMarkers();
  showNewData();
  if (USB.baud() != baud) {
    baud = USB.baud();
       UBLOX.begin(baud);
void recvWithStartEndMarkers()
  static boolean recvInProgress = false;
  static byte ndx = 0;
  char startMarker = '\n';
  char endMarker = '\r';
  char rc;
  uint8_t newValue = 0;
  while (UBLOX.available() > 0 && newData == false)
     newValue = UBLOX.read(); //reads incoming serial data
     rc = (char) newValue;
     //USB.print(newValue);
     if (recvInProgress == true)
      //USB.print("receive in progress");
      //USB.print(rc);
      if (rc != endMarker)
        receivedChars[ndx] = rc;
        ndx++;
        if (ndx >= numChars)
          ndx = numChars -1;
        receivedChars[ndx] = '\0'; // terminate the string
        ndx = 0;
        newData = true;
     else if (rc == startMarker)
        recvInProgress = true;
        //USB.print("seen start marker");
void showNewData()
  if (newData == true)
        USB.print(receivedChars);
        char * pch;
        pch = strstr (receivedChars,"OK");
        if(pch != 0)
          flashLED();
        newData = false;
Just tested with the NB - IoT network, it works. Very happy with the way this turned out!!
langestefan:
#endif
#define powerPin 7
//led setup
  USB.begin(baud);
  UBLOX.begin(baud);
void flashLED()
  delay(100);
    UBLOX.write(c);
  showNewData();
    baud = USB.baud();
      UBLOX.begin(baud);
  char startMarker = ‘\n’;
  char endMarker = ‘\r’;
  char rc;
      //USB.print(“receive in progress”);
      //USB.print(rc);
        ndx++;
          ndx = numChars -1;
        receivedChars[ndx] = ‘\0’; // terminate the string
        ndx = 0;
        newData = true;
        //USB.print(“seen start marker”);
void showNewData()
char * pch;
        pch = strstr (receivedChars,“OK”);
        if(pch != 0)
          flashLED();
newData = false;
