I have just bought a hinged wall mount for my bedroom TV (Microcenter linky) and would like to make a project out of motorizing it. There appears to be plenty of room in and around the arms to add mechanisms and linkages, I just need to figure out how to actuate the hinges.
One solution I thought of was inspired by those linkages bolted to the top of a door that pull it closed and also dampen the closing so that it doesn't slam.
I'm fairly certain I've also seen one of these contraptions motorized so that it could open the door as well.
This linkage would be easy to use on the 1st (by the wall) and 3rd (on the TV plate) hinges that have only 180 degrees of motion. It has the advantage of being incredibly easy to make, I just need to get some flat steel bars from a hardware store and some bearings for the friction.
I need good, thin bearings though. The ones I saw on the Home Depot and Menards website look too think.
The middle hinge is going to be the hardest to deal with, because it has a full 360 degree range of motion with the bolt in the center of the hinge getting in the way of using the double-bar linkage on the inside. I can have the bar mounted on the outside so it goes around the hinge, but that looks ugly. The other downside is that the actuator would need the same range of motion as the hinge, so a nromal servo with 180 degree range would be out: I'd need a continuous rotation one.
So I came up with gear, either directly meshed or a spocket & chain. The upshot of that method is that a 2x multiplying ratio can let me use a 180 degree servo at the expense of doubling my torque requirement.
Problem is, I know less about gears than I know about motors. Where would I even be able to find gears in the sizes I need?
The other major problem is torque. I want there to be some amount of resistance so the mount stays in place with the motors deenergized. By my rough estimate moving it around myself, I may need a few to several ft-lbs or torque to power the arms. Where can I find servos that powerful? If there aren't any that are cheap, what about gears to make my own servo? I'm sure I'll be able to find something about motor control online that I can use to make my own controller (I've downloaded a ton of App Notes from TI, Atmel, Microchip, and other places).
So...bearings, servos, and gears. That's what I need help with.
Please?
