Actuating relays based on sensor values - thread hijack
Hello everyone! I have a question about multiple actuators and sensors… how to make the actuators to switch relay.
example:
if actuator1=“1” ; digitalWrite(water,HIGH);
if actuator2=“0” ; digitalWrite(ventilation,LOW);
if actuator3=“1” ; digitalWrite(power,HIGH);
I don’t know how this work :
String msgString = String(message_buffer).substring(43,44);
Serial.println("message arrived: " + msgString);
if(msgString == “0”)
//if message received is 0, LED is turned off
digitalWrite(LED,LOW);
//if message received is 1, LED is turned on
digitalWrite(LED,HIGH);
source code:
DeviceHUB.net sample code for getting digital actuator state.
In this example an LED is attached to digital pin 5 on the Arduino Ethernet Board.
Download and install PubSubClient library from GitHub - knolleary/pubsubclient: A client library for the Arduino Ethernet Shield that provides support for MQTT.
First open the PubSubClient.h library header file and make the following
modification in that file. (increase the packet size as shown below).
// MQTT_MAX_PACKET_SIZE : Maximum packet size
//#define MQTT_MAX_PACKET_SIZE 128
#define MQTT_MAX_PACKET_SIZE 256
created 26 May 2015
by Alexandru Gheorghe
#include <SPI.h>
#include <Ethernet.h>
#include <PubSubClient.h>
// MAC Address of Arduino Ethernet (Sheild)
byte mac = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
#define API_KEY “paste_your_API_KEY_here”
#define PROJECT_ID “paste_your_PROJECT_ID_here”
//add or remove based on the number of actuators
#define ACTUATOR1_NAME “paste_your_ACTUATOR_NAME_here”
#define ACTUATOR2_NAME “paste_your_ACTUATOR_NAME_here”
#define ACTUATOR3_NAME “paste_your_ACTUATOR_NAME_here”
#define DEVICE_UUID “paste_your_DEVICE_UUID_here”
#define sec 1000
char clientId = “Arduino_Ethernet_test_actx2”;
char actuator1Topic = “/a/“API_KEY”/p/“PROJECT_ID”/d/“DEVICE_UUID”/actuator/“ACTUATOR1_NAME”/state”;
char actuator2Topic = “/a/“API_KEY”/p/“PROJECT_ID”/d/“DEVICE_UUID”/actuator/“ACTUATOR2_NAME”/state”;
char actuator3Topic = “/a/“API_KEY”/p/“PROJECT_ID”/d/“DEVICE_UUID”/actuator/“ACTUATOR3_NAME”/state”;
//Devicehub.net MQTT server
char server = “mqtt.devicehub.net”;
char message_buffer[150];
EthernetClient apiClient;
PubSubClient client(server, 1883, callback, apiClient);
// handles message arrived on subscribed topic
void callback(char* topic, byte* payload, unsigned int length)
// handles extracting the actuator value from payload
int i=0;
int j=0;
int k=0;
for(i=0; i<length; i++){
message_buffer = payload*;*
message_buffer = ‘\0’;
* for(i=0; i<length; i++){*
if(!(strncmp(&message_buffer*, “s”,1) || strncmp(&message_buffer[i+3], “t”, 1))){
_ break;
for(j=i+9; j<length; j++){_
if(!(strncmp(&message_buffer[j], “”",1))){
_ break;
}_
String string_actuator_value = “”;
_ for(k=i+9; k<j; k++){_
string_actuator_value += message_buffer[k];
_ }_
int actuator_value = string_actuator_value.toInt();*
* // here is the value from the actuator*
* Serial.print(topic);*
* Serial.print(" value: ");*
* Serial.println(actuator_value);*
* // you can use it here accordingly just add or remove based on how manny actuators you have*
* if(String(topic) == String(actuator1Topic)){*
* //DO actuator1 action*
* }else if ((String(topic) == String(actuator2Topic))){*
* //DO actuator2 action*
* }else if ((String(topic) == String(actuator3Topic))){*
* //DO actuator3 action*
*void setup(void) *
* // init serial for debugging*
* Serial.begin(9600);*
* if (Ethernet.begin(mac) == 0){*
* Serial.println(“Failed to configure Ethernet using DHCP”);*
* Ethernet.begin(mac);*
* Serial.println("\nStarting connection to server…");*
* if(client.connect(clientId)){*
* //add or remove based on the number of actuators*
* client.subscribe(actuator1Topic);*
* client.subscribe(actuator2Topic);*
* client.subscribe(actuator3Topic);*
* Serial.println(“Successfuly connected and running!”);*
* }else{*
* Serial.println(“Connection problem”);*
*void loop(void) *
* //if client it’s not connected or disconnects here we try to reconnect*
* if (!client.connected()){*
* Serial.println(“reconnecting …”);*
* client.connect(clientId);*
_ delay(3sec);
// MQTT client loop processing*
* client.loop();
}*_
