Actuator selection
I am looking for resources to calculate the load capacity (?) I will need for actuator selection.
I want to move a person, vertcally, up to 5 inches - so a range from 50kg up to 180kg weight-wise.
Taking 180kg as the limit (400lbs), with a physical structure incorporating 2 linear actuators, linked electronically, so they are always moving synchronously, with speed not really being an issue at all (ie slow is fine), should I stick with:
2 x 180kg, 5" actuators or can I divide the work being done between them, and have
2 x 90kg (= 180kg total), 5" actuators?
The movement is vertical, and the simplest (to my inexperienced mind) design would be to have 2 x vertically oriented actuators. Are there better designs or resources / examples for designing this?
I have googled, but knowing the terms to use would be helpful. "Actuators for newbies" seem to stick to mini actuators at hobby robotic level and then there's a leap to industrial applications.
Any website / book suggestions much appreciated.
Thanks
Huh. Since the upgrade my post does not appear. :-/(I theorised adding another post to the thread would change this - hence the reply to self. It worked too ;))
Do the actuators have internal pots for position feedback?
Maybe.
Not sure if it was unclear in my post or thread title, but I am trying to get resources to work out / learn / determine how to select the correct actuators for a project.
In other words, I have an idea, involving actuators, but do not know which ones to choose, due to lack of experience.
Further to this point, because I do not know which ones to select, I have not selected or purchased any.
First order of business is: which load capacity to select.
aarondc:
This book:
...devotes a lot of time, attention and math on the subject (without going in so deep you think you need a higher mathematics degree).
When you get to the choosing stage, or just want a virtual browse 8), have a look at Firgelli.
I can't seem to quote posts, which is as annoying as f#ck, so
@cr0sh: thanks - exactly the sort of thing I am looking for
@JimboZA - yeah! I have been looking through their site and a few others. Seem to be the go-to guys, surprised I didn't find any books or references for reading / study, might look again.
I think the subject I want to look at is "mechatronics"? Can anyone confirm or correct this notion?
Yep, that's it: combination of Mechanics and Electronics afaik
