Ad5940 - Wemos D1 R1
Hi everyone, there's an issue I'm looking forward to a solution. Specifically, I connect my Wemos D1 R1 to 'eval-cn0565-ardz' to measure 4-wire Impedance using AD5940 (SPI). But when I use my oscilloscope, there is no waveform at CE0.
I don't know why. Here is my full version of the code. The value in the code comment is the value I did read from that register
#include <SPI.h>
#define CS_PIN 15    // Chân CS tùy chỉnh
#define SPICMD_SETADDR    0x20      /**< set the register address that is going to operate. */
#define SPICMD_READREG    0x6d      /**< command to read register */
#define SPICMD_WRITEREG   0x2d      /**< command to write register */
#define SPICMD_READFIFO   0x5f      /**< command to read FIFO */
#define REG_CHIPID            0x0404    /* Chip Identification */
#define REG_AFECON_CLKCON0    0x00000408    /* AFECON Clock Divider Configuration */
#define REG_AFECON_CLKSEL     0x00000414    /* AFECON Clock Select */
#define REG_AFECON_CLKEN1     0x00000410    /* AFECON Clock Gate Enable */
#define REG_ALLON_OSCKEY      0x00000A0C    /* ALLON Key Protection for OSCCON */
#define REG_ALLON_OSCCON      0x00000A10    /* ALLON Oscillator Control */
#define REG_AFE_WGFREQ        0x00002030    /* AFE Waveform Generator - Sinusoid Frequency */
#define REG_AFE_WGAMPLITUDE   0x0000203C    /* AFE Waveform Generator - Sinusoid Amplitude */
#define REG_AFE_WGCON         0x00002014    /* AFE Waveform Generator Configuration */
#define REG_AFE_BUFSENCON     0x00002180    /* AFE HP and LP Buffer Control */
#define REG_AFE_LPREFBUFCON   0x00002050    /* AFE LPREF_BUF_CON */
#define REG_AFE_HSDACCON      0x00002010    /* AFE High Speed DAC Configuration */
#define REG_AFE_SWMUX         0x0000235C    /* AFE Switch Mux for ECG */
#define REG_AFE_DSWFULLCON    0x00002150    /* AFE Switch Matrix Full Configuration (D) */
#define REG_AFE_NSWFULLCON    0x00002154    /* AFE Switch Matrix Full Configuration (N) */
#define REG_AFE_PSWFULLCON    0x00002158    /* AFE Switch Matrix Full Configuration (P) */
#define REG_AFE_TSWFULLCON    0x0000215C    /* AFE Switch Matrix Full Configuration (T) */
#define REG_AFE_SWCON         0x0000200C    /* AFE Switch Matrix Configuration */
#define REG_AFE_AFECON        0x00002000    /* AFE Configuration */
#define REG_AFE_DSWSTA        0x000021B0    /* AFE Switch Matrix Status (D) */
#define REG_AFE_PSWSTA        0x000021B4    /* AFE Switch Matrix Status (P) */
#define REG_AFE_NSWSTA        0x000021B8    /* AFE Switch Matrix Status (N) */
#define REG_AFE_TSWSTA        0x000021BC    /* AFE Switch Matrix Status (T) */
/*--------------------------------------------- Read and Write -------------------------------------------*/
void ReadWriteNBytes(unsigned char *pSendBuffer, unsigned char *pRecvBuff, unsigned long length)
  SPI.beginTransaction(SPISettings(160000, MSBFIRST, SPI_MODE0));
  for (int i = 0; i < length; i++)
    pRecvBuff[i] = SPI.transfer(pSendBuffer[i]);
    delay(1);
  SPI.endTransaction();
unsigned char ReadWrite8B(unsigned char data)
  uint8_t tx[1], rx[1];
  tx[0] = data;
  ReadWriteNBytes(tx, rx, 1);
  return rx[0];
uint16_t ReadWrite16B(uint16_t data)
  uint8_t SendBuffer[2];
  uint8_t RecvBuffer[2];
  SendBuffer[0] = data >> 8;
  SendBuffer[1] = data & 0xFF;
  ReadWriteNBytes(SendBuffer, RecvBuffer, 2);
  return (((uint16_t)RecvBuffer[0]) << 8) | RecvBuffer[1];
uint32_t ReadWrite32B(uint32_t data)
  uint8_t SendBuffer[4];
  uint8_t RecvBuffer[4];
  SendBuffer[0] = (data >> 24) & 0xFF;
  SendBuffer[1] = (data >> 16) & 0xFF;
  SendBuffer[2] = (data >> 8)  & 0xFF;
  SendBuffer[3] = (data)       & 0xFF;
  ReadWriteNBytes(SendBuffer, RecvBuffer, 4);
  return (((uint32_t)RecvBuffer[0]) << 24) | (((uint32_t)RecvBuffer[1]) << 16) | (((uint32_t)RecvBuffer[2]) << 8) | RecvBuffer[3];
void WriteReg(uint16_t RegAddr, uint32_t RegData)
  digitalWrite(CS_PIN, LOW);
  ReadWrite8B(SPICMD_SETADDR);
  ReadWrite16B(RegAddr);
  digitalWrite(CS_PIN, HIGH);
  ReadWrite8B(SPICMD_WRITEREG);
  if (((RegAddr >= 0x1000) && (RegAddr <= 0x3014)))
    ReadWrite32B(RegData);
    ReadWrite16B(RegData);
uint32_t ReadReg(uint16_t RegAddr)
  uint32_t Data = 0;
  ReadWrite8B(SPICMD_READREG);
  ReadWrite8B(0);
  if ((RegAddr >= 0x1000) && (RegAddr <= 0x3014))
    Data = ReadWrite32B(0);
    Data = ReadWrite16B(0);
  return Data;
  SPI.begin();
  pinMode(CS_PIN, OUTPUT);
  Serial.println("");
  Serial.print("ID =");
  Serial.println(ReadReg(REG_CHIPID), HEX); // Chip ID // (0x5502)
  //--------------------------------------------- Initialization -------------------------------------------------
  WriteReg(0x0908, 0x2c9); // (0x2C9)
  WriteReg(0x0c08, 0x206C); // (0x206C)
  WriteReg(0x21F0, 0x0010); // (0x10)
  WriteReg(0x0410, 0x2C9); // (0x1C9)
  WriteReg(0x0A28, 0x0009); // (0x9)
  WriteReg(0x238c, 0x0104); // (0x0104)
  WriteReg(0x0a04, 0x4859); // (0x4859)
  WriteReg(0x0a04, 0xF27B); // (0xF27B)
  WriteReg(0x0a00, 0x8009); // (0x8009)
  WriteReg(0x22F0, 0x0000); // (0x21000)
  // ------------------------------------------------- Clock -----------------------------------------------------------
  // ReadReg(REG_AFECON_CLKCON0); // [Done] - System and ADC clock frequency 16MHz // (0x441)
  // ReadReg(REG_AFECON_CLKSEL); // [Done] - System and ADC clock source // (0x0)
  // ReadReg(REG_AFECON_CLKEN1); // [Done] - Turn on ACLK clock [bit 5 = 0] // (0x1C9)
  // ReadReg(REG_ALLON_OSCCON); // - Enable clock [bit 0 = 1] [bit 1 = 1]  // (0x303)
  // --------------------------------------- Waveform Generator ---------------------------------------------------------
  WriteReg(REG_AFE_WGFREQ, 0x333333); // [Done] - Waveform freq : f = f_aclk * data /(2^30) where f_aclk = 16MHz, data = 0x333333 => f = 50kHz (0x333333)
  WriteReg(REG_AFE_WGAMPLITUDE, 0x4ff); // [Done] - Waveform Amp // (0x4ff)
  WriteReg(REG_AFE_WGCON, 0x4); // [Done] - // Sine Waveform and Bypass DAC // (0x4)
  //------------------------------------ HIGH AND LOW POWER DAC & EXCITATION BUFFER ----------------------------------------------------
  // ReadReg(REG_AFE_BUFSENCON); // [Done] - High power and low buffer control // (0x37)
  // ReadReg(REG_AFE_LPREFBUFCON); // [Done] - Enable low-power reference and 2.5V buffer // (0x0)
  // ReadReg(REG_AFE_HSDACCON); // [Done] - Excitation Buffer Gain = 2, Attenuation = 1 and Rate = 15 // (0x1E)
  //-------------------------------------- Switch Matrices -------------------------------------------------
  WriteReg(REG_AFE_DSWFULLCON, 0x10); // Close D5 // (0x10)
  WriteReg(REG_AFE_PSWFULLCON, 0x10); // Close P5 // (0x10)
  WriteReg(REG_AFE_NSWFULLCON, 0x2); // Close N2 // (0x2)
  WriteReg(REG_AFE_TSWFULLCON, 0x102); // Close T2 and T9 // (0x102)
  WriteReg(REG_AFE_SWCON, 0x32255); // Update switch configuration (T9 = 1 bit 17, SWSource = 1, close D5, N2, P5 and T2) // (0x32255)
  // ReadReg(REG_AFE_DSWSTA); // (0x10);
  // ReadReg(REG_AFE_PSWSTA); // (0x10);
  // ReadReg(REG_AFE_NSWSTA); // (0x2);
  // ReadReg(REG_AFE_TSWSTA); // (0x102);
  // ----------------------------------------- General Configuration --------------------------------------------
  WriteReg(REG_AFE_AFECON, 0x39CFC0); // Enable DAC (bit 20, 21) = 1, Waveform Generator = 1, Excitation = 1, ADC = 1, HS reference = 0
  // Nothing here for now
Someone helps me handle it. Thank you ^^.
You posted this in the "Uno" category of the forum but you're using a Wemos D1 R1. Hence your topic has been moved to a more suitable location on the forum.
I can't help you with your problem.
How are you powering the AD5940? I assume with the WeMos device which would be just fine. Can you post a schematic, that part doubles up on several of the GPIO pins where they connect to a different pin on the board. You get only about 1/2 of the I/O. It is a nice part.
