AD7019R yielding strange data
Hello, I am working on a vibration analysis program in LabView that uses data from a piezo accelerometer. I've got an Analog Devices CN0350 charge amplifier/adc board that is communicating via SPI with a Due, which is using native USB to send the data to LabView. However, I'm getting strange results from the adc; if I slowly shake the accelerometer, instead of reading a smooth sine wave, the waveform is rough and past a certain amplitude, looks like the peaks are either clipping or sometimes even getting transposed to the center. I reconfigured the charge amplifier to match my accelerometer but verified with an oscilloscope that it is working correctly and within the voltage range of the adc. And it's not a LabView issue, since the incoming data looks the same in the Arduino IDE's serial monitor/plotter. I attached a screenshot from LabView and put the code below. I found this program in another thread but modified it slightly for native usb and to print a formatted string. Any advice would be greatly appreciated. Thanks!
#include<SPI.h>
#define CONVST 9
#define SS 10
char format[50];
void AD7091R_init_conv() {
  digitalWrite(CONVST, LOW);
  delayMicroseconds(1);
  digitalWrite(CONVST, HIGH);
void AD7091R_soft_reset() {
  AD7091R_init_conv();
  digitalWrite(SS, LOW);
  SPI.transfer(0x00);
  digitalWrite(SS, HIGH);
   //Initialize serial and wait for port to open:
  SerialUSB.begin(9600);
  while (!SerialUSB) {
    ; // wait for serial port to connect. Needed for native USB
 // Serial.begin(115200);
  SPI.begin();
  pinMode(CONVST, OUTPUT);
  pinMode(SS, OUTPUT);
  AD7091R_soft_reset();
  uint16_t val = SPI.transfer(0x00); //receive bits 11-4
  byte x = SPI.transfer(0x00); //receive bits 3-0 (will be in bits 7-4 of x)
  val = (val << 4) | (x >> 4); //combine the 12 bits read
  val &= 0x0FFF; //masking
  sprintf(format, "%4d", val);
  SerialUSB.println(format); //this is the 12bit ADC value 0-4095
  //Serial.println(val);
  delayMicroseconds(300); //arbitrary loop delay
Maybe its the bit order. Your ADC sends MSB first. How do you know what the SPI module "thinks" arrives first?
You could set the voltage at the ADC with a variable voltage divider and make sure the bits are in the order and at the position you expect them.
