AD7152 TO Arduino
Hello everyone, I am using EVAL-AD7152 to get the capacitance data from a 2pF ceramic capacitor, but the Arduino can not read the capacitance value of AD7152, I use 3.3V arduino mega2560 as my master device, and my slave device is 3.3V. Below is my code.
#include <Wire.h>
#define AD7152_I2C_ADDRESS 0x48 //AD7152 adress
#define AD7152_REG_STATUS 0x00
#define AD7152_REG_CH1_DATA_MSB 0x01
#define AD7152_REG_CH1_DATA_LSB 0x02
#define AD7152_REG_CH1_SETUP 0x0B
#define AD7152_REG_CONFIGURATION 0x0F
byte myArray = {219, 0, 0, 0, 49, 0, 255}; //SETUP Reg, x, x, x, CONFIG REg
Wire.begin();
Wire.beginTransmission(AD7152_I2C_ADDRESS);
Wire.write(AD7152_REG_CH1_SETUP); //Move pointer to the SETUP register address
Wire.write(myArray, sizeof(myArray)); //see global arry declaration
byte busStatus = Wire.endTransmission();
delay(4);
if(busStatus !=0)
Serial.println(“I2C Communication problem…!”);
while(1); //wait for ever
Wire.beginTransmission(AD7152_I2C_ADDRESS); // “Hey, AD7152 @ 0x48! Message for you”
Wire.write(AD7152_REG_STATUS); //pointing Status Register
delay(4);
do
Wire.requestFrom(AD7152_I2C_ADDRESS, 1); //if conversion complete, we can read data bytes also
while(Wire.read() != 0x52); //at busy–Wire.read() = Status Register 0x53; else Wire.read() = 0x52
Wire.write(AD7152_REG_CH1_DATA_MSB); //pointing DATA_H Register
delay(4);
Wire.requestFrom(AD7152_I2C_ADDRESS, 2);
int ch1 = (int)Wire.read() <<8 | (int) Wire.read();
float Cap1 = (ch1 - 0x8000) / 0xFFF0; //Converts digital value into capacitance, formula from datasheet.
//print the data on serial monitor
Serial.print(“Ch1=”); Serial.print(ch1, BIN);
Serial.print(" Ch1="); Serial.print(ch1, DEC);
Serial.print(" C1="); Serial.println(Cap1, 4);
delay(700);
I’m really new to coding… so this may be nonsense, but for an Int the Arduino reference states
“On the Arduino Uno (and other ATMega based boards) an int stores a 16-bit (2-byte) value.”
In your code you have
Doesn’t ch1 need to be 4 bytes to work in your formula?
As said I’m learning, so I would like to know the answer.
