AD7193 reads wrongly for certain weights
I am using AD7193 for reading load cell. While reading the certain weights, the scales do not fit. For example, I measure 5, 10, 15 kg. Then, the range of 5 and 15 kg is propotional ,but 10 kg gives not proper value.
The attachment shows us the figure I obtained. First step is 5 kg, second is 10 and third is 15 kg.
To come up my question, why does the IC give wrong value at 10 kg?
It's probably your code.
Post a link to the device. Post a schematic showing how it is connected to the Arduino. Post your code.
These are the codes from github for arduino due.
Firstly, main.ino
#include <SPI.h>
#include "AD7193.h"		// AD7193 definitions.
#define AD7193_RDY_STATE        MOSI
#define PMOD1_CS_PIN  4// SS
#define PMOD1_CS_LOW digitalWrite(PMOD1_CS_PIN,LOW);
#define PMOD1_CS_HIGH digitalWrite(PMOD1_CS_PIN,HIGH);
#define AD7193_CH_0      0
unsigned char currentPolarity = 1;
unsigned char currentGain     = 0;
unsigned char AD7193_Init(void)
    unsigned char status = 1;
    unsigned char regVal = 0;
	/*! Initialize SPI communication. */
	SPI.begin(PMOD1_CS_PIN);
	SPI.setDataMode(PMOD1_CS_PIN,SPI_MODE3);
	//SPI.setClockDivider(SPI_CLOCK_DIV4);
        SPI.setClockDivider(PMOD1_CS_PIN,2);// arduino DUE
    AD7193_Reset();
    regVal = AD7193_GetRegisterValue(AD7193_REG_ID, 1, 1);
    if( (regVal & AD7193_ID_MASK)  != ID_AD7193)
        status = 0;
    return status;
void AD7193_SetRegisterValue(unsigned char registerAddress,
                              unsigned long registerValue,
                              unsigned char bytesNumber,
                              unsigned char modifyCS)
    unsigned char commandByte = 0;
    unsigned char txBuffer[4] = {0, 0, 0 ,0};
    commandByte = AD7193_COMM_WRITE | AD7193_COMM_ADDR(registerAddress);
        txBuffer[0] = (registerValue >> 0)  & 0x000000FF;
	txBuffer[1] = (registerValue >> 8)  & 0x000000FF;
	txBuffer[2] = (registerValue >> 16) & 0x000000FF;
	txBuffer[3] = (registerValue >> 24) & 0x000000FF;
	if(modifyCS == 1)
		digitalWrite(PMOD1_CS_PIN, LOW);
	SPI.transfer(PMOD1_CS_PIN,commandByte);
    while(bytesNumber > 0)
        SPI.transfer(PMOD1_CS_PIN, txBuffer[bytesNumber - 1]);
        bytesNumber--;
	if(modifyCS == 1)
		digitalWrite(PMOD1_CS_PIN, HIGH);
unsigned long AD7193_GetRegisterValue(unsigned char registerAddress,
    unsigned char receiveBuffer = 0;
    unsigned char writeByte = 0;
    unsigned char byteIndex = 0;
    unsigned long buffer = 0;
    writeByte = AD7193_COMM_READ | AD7193_COMM_ADDR(registerAddress);
    if(modifyCS == 1)
	SPI.transfer(PMOD1_CS_PIN,writeByte);
    while(byteIndex < bytesNumber)
        receiveBuffer = SPI.transfer(PMOD1_CS_PIN,0);
	buffer = (buffer << 8) + receiveBuffer;
        byteIndex++;
    if(modifyCS == 1)
    return(buffer);
void AD7193_SetMode(unsigned char mode)
    unsigned long oldRegValue = 0;
    unsigned long newRegValue = 0;
    oldRegValue = AD7193_GetRegisterValue(AD7193_REG_MODE, 3, 1);
    oldRegValue &= ~AD7193_MODE_SEL(0x7);
    newRegValue = oldRegValue | AD7193_MODE_SEL(mode);
    AD7193_SetRegisterValue(AD7193_REG_MODE,newRegValue,3,1);
void AD7193_Reset(void)
    char i = 0;
	for(i = 0; i < 6; i++)
		SPI.transfer(PMOD1_CS_PIN,0xFF);
void AD7193_SetPower(unsigned char pwrMode)
     unsigned long oldPwrMode = 0x0;
     unsigned long newPwrMode = 0x0;
     oldPwrMode = AD7193_GetRegisterValue(AD7193_REG_MODE, 3, 1);
     oldPwrMode &= ~(AD7193_MODE_SEL(0x7));
     newPwrMode = oldPwrMode |
                  AD7193_MODE_SEL((pwrMode * (AD7193_MODE_IDLE)) |
                                  (!pwrMode * (AD7193_MODE_PWRDN)));
     AD7193_SetRegisterValue(AD7193_REG_MODE, newPwrMode, 3, 1);
void AD7193_WaitRdyGoLow(void)
    while(digitalRead(AD7193_RDY_STATE));
void AD7193_ChannelSelect(unsigned short channel)
    unsigned long oldRegValue = 0x0;
    unsigned long newRegValue = 0x0;
    oldRegValue = AD7193_GetRegisterValue(AD7193_REG_CONF, 3, 1);
    oldRegValue &= ~(AD7193_CONF_CHAN(0x3FF));
    newRegValue = oldRegValue | AD7193_CONF_CHAN(1 << channel);
    AD7193_SetRegisterValue(AD7193_REG_CONF, newRegValue, 3, 1);
void AD7193_Calibrate(unsigned char mode, unsigned char channel)
    AD7193_ChannelSelect(channel);
    PMOD1_CS_LOW;
    AD7193_SetRegisterValue(AD7193_REG_MODE, newRegValue, 3, 0); // CS is not modified.
    AD7193_WaitRdyGoLow();
    PMOD1_CS_HIGH;
void AD7193_RangeSetup(unsigned char polarity, unsigned char range)
    oldRegValue = AD7193_GetRegisterValue(AD7193_REG_CONF,3, 1);
    oldRegValue &= ~(AD7193_CONF_UNIPOLAR |
                     AD7193_CONF_GAIN(0x7));
                  (polarity * AD7193_CONF_UNIPOLAR) |
                  AD7193_CONF_GAIN(range);
    /* Store the last settings regarding polarity and gain. */
    currentPolarity = polarity;
    currentGain = 1 << range;
unsigned long AD7193_SingleConversion(void)
    unsigned long command = 0x0;
    unsigned long regData = 0x0;
    command = AD7193_MODE_SEL(AD7193_MODE_SINGLE) |
              AD7193_MODE_CLKSRC(AD7193_CLK_INT) |
              AD7193_MODE_RATE(0x060);
    PMOD1_CS_LOW;
    AD7193_SetRegisterValue(AD7193_REG_MODE, command, 3, 0); // CS is not modified.
    regData = AD7193_GetRegisterValue(AD7193_REG_DATA, 3, 0);
    PMOD1_CS_HIGH;
    return regData;
unsigned long AD7193_ContinuousReadAvg(unsigned char sampleNumber)
    unsigned long samplesAverage = 0;
    unsigned long command        = 0;
    unsigned char count          = 0;
    command = AD7193_MODE_SEL(AD7193_MODE_CONT) |
    PMOD1_CS_LOW;
    for(count = 0; count < sampleNumber; count++)
        samplesAverage += AD7193_GetRegisterValue(AD7193_REG_DATA, 3, 0); // CS is not modified.
    PMOD1_CS_HIGH;
    samplesAverage = samplesAverage / sampleNumber;
    return samplesAverage;
unsigned long AD7193_TemperatureRead(void)
    unsigned long dataReg     = 0;
    unsigned long temperature = 0;
    AD7193_RangeSetup(0, AD7193_CONF_GAIN_1); // Bipolar operation, 0 Gain.
    AD7193_ChannelSelect(AD7193_CH_TEMP);
    dataReg = AD7193_SingleConversion();
    dataReg -= 0x800000;
    temperature = dataReg / 2815;    // Kelvin Temperature
    temperature -= 273;              // Celsius Temperature
    return temperature;
float AD7193_ConvertToVolts(unsigned long rawData, float vRef)
    float voltage = 0;
    if(currentPolarity == 0 )   // Bipolar mode
        voltage = (((float)rawData / (1ul << 23)) - 1) * vRef / currentGain;
    else                        // Unipolar mode
        voltage = ((float)rawData * vRef) / (1ul << 24) / currentGain;
    return voltage;
   unsigned long regValue = 0;
   delay(7000);
  if(AD7193_Init())
      Serial.print("AD7193 OK");
      Serial.print("AD7193 Error");
  /*! Resets the device. */
    AD7193_Reset();
    Serial.print("\n");
    Serial.print("reset OK");
    Serial.print("\n");
    /*! Select Channel 0 */
    AD7193_ChannelSelect(AD7193_CH_0);
    Serial.print("chanel OK");
    Serial.print("\n");
    /*! Calibrates channel 0. */
    AD7193_Calibrate(AD7193_MODE_CONT, AD7193_CH_0);
    Serial.print("calibrate OK");
    Serial.print("\n");
    /*! Selects unipolar operation and ADC's input range to +-2.5V. */
    AD7193_RangeSetup(0, AD7193_CONF_GAIN_128);
    Serial.print("range OK");
    Serial.print("\n");
    regValue = AD7193_GetRegisterValue(AD7193_REG_CONF, 3, 1);//
  //  regValue |= AD7193_CONF_PSEUDO;//
    regValue &= (0 << 18);
    AD7193_SetRegisterValue(AD7193_REG_CONF, regValue, 3, 1);//
  unsigned long data = 0;
  data = AD7193_ContinuousReadAvg(100);
  float volt=AD7193_ConvertToVolts(data,5);
  Serial.print("volt=");
  Serial.println(volt,DEC);
AD7193.h (12.1 KB)
Does printing the voltage to 10 decimal places make sense?
Why not? It prints the voltage values in decimal.
Actually it does not matter because I can print rawdata in decimal format over 16777215 as 2^24.
What type is that? Only Microsoft uses that type, to deal with money to two decimal places.
In your code, volt is a float. The second argument to print(), when the first is a float, is the number of decimal places to print. DEC is 10, so you are printing a float to 10 decimal places.
Does that make sense? Is the value really accurate to 10 decimal places?
Actually, I think it is not problem for my project. On the other hand, I want to learn how it does not make sense. I can omit the DEC from there or What do you suggest for that?
If the scale can accurately weigh to the nearest ounce, and you put 3 half ounce oblects on it, does it make sene to say that the weight of the objects on the scale is 1.0000000000 ounces?
My claim is that it does not.
According to my last experience on AD7193, the ic does not response to some voltage values while reading binary values of it. In other words, when I vary the input voltage linearly via trimpot (I get 10 datas for every 50mV change), the chart does not give me proper shape.
Am I still testing the ic wrongly? I can't really understand.
