AD7711 to measure temperature!
Hi, has any of you ever tryed an AD7711 coupled with ARDUINO uno? I would develop a temperature monitor but first i should make the AD converter working! I am using a breadboard for the proto and simply powering, setting the MODE pin and adding the quartz do not give any result i.e. neither i have SCLK output.. Moreover the serial interface of the device is not standard and has only bi-directional SDATA, so i am wondering if connecting it to both MISO and MOSI would create some issues Any tip? thank you!
Please post a link to the datasheet of the sensor, I now have too little info to help
Also post the code you have tested so far, and explain what does not work, what you expected
